Right rear shock needs replacing....
Old Nov 7, 2005 | 04:57 PM
TinkySD's Avatar
Audi Driving Snob
Ufortunately I've notice over the past few thousand miles a squeaking coming from my right rear shock when going over speed bumps. At first I thought it was just all the crap I had in the trunk but unfortunately it seems like the shock is pretty much toast.
I'm thinking it might be a good opportunity to upgrade to the a-spec package -- anyone know of any good deals or groubbuys on it right now?
Old Nov 7, 2005 | 05:02 PM
jlukja's Avatar
check Acura of Escondido on e-bay. When I price things they usually are the lowest cost provider. And, they are really good to deal with.
Old Nov 7, 2005 | 05:09 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Check the black market section. And definitely look at Acura of Escondido like Jlukja mentions. I think they are based out of Washington, so you won't get charged sales tax.
...or you could just say forget the aspec and get a reflash
Old Nov 7, 2005 | 05:23 PM
jlukja's Avatar
LOL, Kenny, AofE is in Escondido, about a half hour drive north of San Diego on I-15.
Old Nov 7, 2005 | 06:26 PM
ILoveMyHonda's Avatar
17781708
But yeah i reccommend Acura of Escondido, CA too
or if you want shock spring package, you can always go TEIN Basic, whats wrong with that
Old Nov 7, 2005 | 07:36 PM
TinkySD's Avatar
Audi Driving Snob
I'll have to double check that it isnt' something like the endlink on the right rear side being broken; which just occursed to me. I'd assumed it was the shock.
What's the best way to test that the shock is, in fact, the culprit?
Old Nov 7, 2005 | 08:24 PM
JTso's Avatar
Originally Posted by TinkySD
I'll have to double check that it isnt' something like the endline on the right rear side being broken; which just occursed to me. I'd assumed it was the shock.
The old way of bouncing the car up and down doesn't seem to work with the newer stiffer suspension. The easiest way is to check for oil leak around the shock. However, if the shock is simply worn out, you might not see oil leak. Then the next step is to remove the entire assembly and inspect the compression and rebound strokes of the piston shaft for smooth operation (without the spring).
Old Nov 8, 2005 | 01:44 AM
Tsx536's Avatar
Rep'n Taxbrain.com
Ooops my bad! I remember there being an Acura Dealer that sells on Ebay based out of Washington. I forget who it is then.
Old Nov 8, 2005 | 05:57 AM
moda_way's Avatar
I noticed oil leaking out of my wife's Civic's driverside front strut. When I had to replace the front struts (always replace as a set), it was a freakin mess and you could easily tell that the strut had failed aside from the oil. The strut rod wouldn't even hold up under its own weight.
What's up with the new Avatar JTso??
Old Nov 8, 2005 | 07:51 AM
xizor's Avatar
Bye TSX, hello domestic?
I had a similar problem (probably induced from aftermarket springs) where my right passenger shock would squeek. It sounded like a bird chirping, I ignored it for a while by playing music louder and it eventually went away, maybe it was the weather
Old Nov 8, 2005 | 10:12 AM
TinkySD's Avatar
Audi Driving Snob
I'm going to check it out this weekend and see if there is any oil and that my endlink is still in tact.
Old Nov 8, 2005 | 11:54 AM
JTso's Avatar
I traded in my TSX for a Bugatti.
I meant the TSX avatar.
Dec 7, 2020 05:39 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Sep 17, 2015 09:01 PM
Sep 17, 2015 10:16 AM
d.lim
Sep 15, 2015 08:54 PM
