Reving question
Old Aug 9, 2010 | 07:55 PM
nothome17's Avatar
Reving question
I have an 2004 Acura TSX manual and recently found out that i can only rev my engine up to 4 1/2 rpms when car is in neutral. Other than that, all 6 gears can go past 4 1/2 rpms.
Does anyone know whats causing this issue.
Old Aug 9, 2010 | 07:56 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Do you have the parking brake engaged while in neutral?
Old Aug 9, 2010 | 08:01 PM
nothome17's Avatar
I did, let me try having it down.
Old Aug 9, 2010 | 08:07 PM
Report back.
Old Aug 9, 2010 | 08:13 PM
main70072's Avatar
It's the limiter, a feature that helps to prevent premature wear on engine parts. Unless car is in gear, you can only rev it to 4,500 RPM.
Old Aug 9, 2010 | 08:16 PM
PACman's Avatar
If I recall correctly, this is normal. When not in motion and in neutral gear, the rev limiter is 4500rpm.
Old Aug 9, 2010 | 09:45 PM
nothome17's Avatar
I tried with the hand breaks down and still the same. I figured its odd to have a limiter at neutral.
i also tried pressing in the clutch and reving and same results.
Old Aug 9, 2010 | 09:59 PM
Itchytoe's Avatar
Modding newbie
Why rev past 4500 when you're not in gear?
Old Aug 9, 2010 | 10:36 PM
Did you have your foot on the brake?
Old Aug 9, 2010 | 10:54 PM
nothome17's Avatar
i put it in first gear and rev but stopped at 4 1/2. And no my foot was not on the breaks.
Old Aug 9, 2010 | 10:57 PM
I see. So you did not have the parking brake engaged, nor had your foot on the brake?
Maybe the car has to be in motion...
Old Aug 9, 2010 | 11:00 PM
lightjak_tsx's Avatar
thank you for this info
Old Aug 10, 2010 | 06:11 PM
nothome17's Avatar
Okay, the car has to be in motion in order for the engine to be rev'd over 4000 rpms.
Old Aug 10, 2010 | 10:12 PM
main70072's Avatar
That's what we were trying to tell you, and it's normal to prevent engine damage.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
