Replacing radiator, other stuff to replace
Old Apr 1, 2016 | 05:42 PM
Ck98vteC's Avatar
I had some spray under the hood the top part has a leak where it meets the aluminum. I got a new Denso radiator and new upper and lower hoses too. Should I go ahead and do the thermostat too? I heard the oem ones are very reliable and I never had problems in the winer.
Old Apr 1, 2016 | 08:05 PM
01acls's Avatar
If not now, when will you replace it?
What are the chances of you having a better time than right now when you're replacing the rad and hoses?
Same goes for the rad cap too.
Old May 7, 2016 | 02:54 PM
louislagerfeld's Avatar
the same thing happened to my TSX about a year ago
There was a DIY thread here(I think) and I went ahead with the replacement. I had my dad help me out since the hoses were pretty tight. If you have all the right tools it should take no longer than 3 hours to do. I ordered the radiator from RockAuto and if I remember correctly it came with a new thermostat. Make sure you replace the radiator cap as well.
