Rear Window Brake lights out
Old Nov 19, 2008 | 09:30 AM
holly's Avatar
3rd Gear
Help! My 04 TSXs rear window brake light is out. I'm not sure if its a fuse or just the lights. Does anyone know if the lights are serial or parallel? I don't want to buy new light bulbs if this is a known issue and if its a fuse or wiring problem. Anyone? Thanks
Old Nov 19, 2008 | 09:35 AM
litesout's Avatar
Oliver!!!
It's probably just a blown bulb. In the trunk right under the light socket. Just give it a quarter turn and it'll drop right out. No tools required.
Old Nov 19, 2008 | 10:20 AM
PACman's Avatar
You can use one of the mono filament tail light bulbs (that's still operational) to check if it's a blown rear center bulb. Simply remove it from one of the tail lights, and insert to the rear center, apply the brake, and look at your rearview mirror. If you see a glow of rear around the rear center housing, then you have confirmed it was a blown bulb.
You can find replacement bulbs at Pep Boys.
Old Nov 19, 2008 | 10:47 AM
PACman's Avatar
Edit: the periphery of the rear center housing glow red as you apply the brake pedal in the dark, like in the garage.
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
nanos
Nov 12, 2015 08:41 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
Ny1718
Sep 11, 2015 09:21 AM
