Rear driver side wheel screech.
Lately I have been getting a screech coming from my driver side rear. It is intermittent but, can be aggravated when hitting reflectors closely positioned on the road. I am not sure how common it is for our rear bearing to give, I only have 45k on the car. I still need to see if bearings are under warranty as she is only an 08. I was also thinking it could be my read pads moving around causing the squeak plate to make contact. I am near having to replace the rear pads.
No its not screeching when braking. I am going to pull off the wheel tomorrow and check everything out. I was just curious if anyone else had a similar issue and if Acura warranties the bearing if that's the issue.
nanos
11-12-2015 08:41 PM
09-04-2015 08:03 AM
