Rattling from Springs
Old Jul 24, 2004 | 05:28 PM
slobeatz's Avatar
Littering and.....
I had eibach pro-kit springs installed a week ago and had the alignment done today. I seem to have a rattling nose coming from the rear springs. It seems like it happens when I hit a dip in the road and the spring would be extended. Is it just because of the difference in spring height or could it be a serious problem? I checked the upper bolts and they are on tight, the lower bolts were screwed in with an impact gun so I don't think they'll be lose. Any ideas? Thanks for the help!
Old Aug 1, 2004 | 10:32 AM
slobeatz's Avatar
Littering and.....
Anybody? It's driving me crazy!
Old Aug 1, 2004 | 11:07 AM
biker's Avatar
If you know for sure it's the springs I'd have someone else look at it. Make sure that all of the other stuff that got touched during the install is also tight.
Old Aug 1, 2004 | 12:31 PM
xizor's Avatar
Bye TSX, hello domestic?
I installed my prokit last week and have no noises coming from mine. Are you springs seated correctly in the strut?
Old Aug 1, 2004 | 12:46 PM
slobeatz's Avatar
Littering and.....
I think they are? It's actually really weird because I get no noises when I hit large bumps. I double checked to make sure that everything is on tight and I get no movement in the struts or springs when I tug on them a bit.
Old Aug 1, 2004 | 01:16 PM
slobeatz's Avatar
Littering and.....
Well, I took the back seat out just to triple check everything and after I got it out, I pushed down on the car to look for any sounds. It seems that the sound may not be coming from the springs but from somewhere else. I guess I'll have to look into it more.
Old Aug 2, 2004 | 05:08 PM
slobeatz's Avatar
Littering and.....
Would the springs being in upside down cause it?
Old Aug 2, 2004 | 06:01 PM
xizor's Avatar
it be pretty hard to put them in upside down, make sure the lettering is rightside up and I believe the plastic wrapping the spring is at the top.
Old Aug 2, 2004 | 10:44 PM
slobeatz's Avatar
Littering and.....
Nope, they're in upside down. I guess we just weren't paying attention to the lettering.
Don't I feel like a dumbass
Old Aug 3, 2004 | 08:08 PM
slobeatz's Avatar
Littering and.....
Well....I re-did the springs and put them in right this time. But...the rattling is still there. I talked to a buddy of mine and he said he had eibach springs once and had the same problem, but never could figure out why they rattled. Oh well, maybe some dynamat around the area will conceal the sound.
Old Aug 3, 2004 | 09:05 PM
Stokeless_TSX's Avatar
Stokeless
just turn ur music up =)
Old Aug 3, 2004 | 11:40 PM
xizor's Avatar
did you get an alignment? just a possibility
Old Aug 4, 2004 | 07:45 AM
slobeatz's Avatar
Littering and.....
Yeah, I got an alignment about a week ago. Oh well, looks like I'll just have to search the web to see if anybody has come up with a solution. Maybe I'll call eibach and see if they can give any advice.
Old Nov 7, 2004 | 04:43 PM
Triz08's Avatar
Im having the same problems, its pretty bad noises coming from them. Cannot figure out what is causing it!
Old Nov 7, 2004 | 05:15 PM
xizor's Avatar
strangely enough this just started happening to me. i installed them originally w/ my comptech sway bar and didn't have any problems, but i just went back to the stock one and i'm getting some serious noise. my guess is b/c the OEM flexes so much, its allowing the rear springs to extend farther
Old Nov 7, 2004 | 07:12 PM
slobeatz's Avatar
Littering and.....
Xizor, I just posted in Triz08's post and said that I had the noise until I put the comptech rear-sway bar on. Weird
Old Nov 8, 2004 | 12:30 AM
tsxhondatuner's Avatar
6 speed yo!
i dont have noise on my springs :/
Old Nov 8, 2004 | 02:31 PM
xizor's Avatar
well your drop is slightly less I believe, who knows
Old Nov 8, 2004 | 02:53 PM
dzuy's Avatar
Troutslap Mod-DUH-rator
i don't have any noise issues either. AND i'm rollin on some low pro tires too.
weird.
Old Nov 8, 2004 | 03:10 PM
xizor's Avatar
weird.
did you install the springs yourself? i'm wondering it not compressing the rear springs when they're put on makes a difference.
Old Nov 9, 2004 | 12:11 AM
Triz08's Avatar
a buddy of mine did tsxondubs he used a hydrolic spring compressor, it seemed like everything went on like it should...
Old Nov 9, 2004 | 12:25 AM
6 speed yo!
what does the pro kit lower?
the only reason why i went TEIN was cause of the drop was more than pro kit i believe.
Old Nov 9, 2004 | 01:03 AM
Triz08's Avatar
looks like ill have to try out the rear sway bar then....
Old Nov 9, 2004 | 07:57 AM
slobeatz's Avatar
Littering and.....
Pro-kit does 1.4 front / 1.6 rear or the other way around, I forget.
Old Nov 9, 2004 | 09:13 AM
xizor's Avatar
1.6F/1.4R
Old Nov 10, 2004 | 09:47 PM
xizor's Avatar
just put my new sway bar on and 99.9% of the rattling went away. I heard 1 quiet pop in a 10minute drive. I'm going to take apart my shock/spring this weekend to see if I can get to the root of the problem, the spring seems to be sitting in the perches just fine. I swear the sound is coming from the top of the shock where its mounted but its bolted on tight. jtso suggested the top bushing could be causing noise so I'm going to look into it. but AFAIK its a non-problem once I got my sway bar back on.
Old Nov 15, 2004 | 02:04 PM
Triz08's Avatar
Well i just went under the car and decided to check all the bolts. I found that you have to use an allen key in the sway bar bolt to tighten it completely. After tightening that and 1 or 2 other bolts, the problem seemed to be completely fixed!
So try it out and see what happens
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
CarlosILX13
ILX Performance Parts & Modifications
14
Jul 11, 2016 11:07 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
