rattle when AC is on
Old Jul 19, 2006 | 06:39 AM
PearlWhite05's Avatar
I was wondering if any of you guys get a slight rattle/vibration when the car is at idle with the AC on. Once I am on the throttle it disappears.
Is this normal?
Old Jul 19, 2006 | 06:45 AM
jiggaman's Avatar
I spend 2 much time here
u have comptech headers?
Old Jul 19, 2006 | 08:07 AM
Mockenrue's Avatar
Arriving Somewhere...
I have a creaking noise from my steering wheel that seems to be worse when the A/C is on. I haven't figured out how that could be correlated. It only makes the sound when turning the wheel. Anyone else have this issue?
Old Jul 19, 2006 | 11:58 AM
Yes I have Comptech headers. But I just took my RT Cat. off and put the Stock Cat. on did this occur, when I had my RT Cat. on there was no vibrations
If it is a normal thing I don't mind it, its not that strong (the rattle). I just want to make sure its normal.
Old Jul 19, 2006 | 12:18 PM
jiggaman's Avatar
it appears that this rattle with comptech headers is more common than originally thought, call comptech and report it
Old Jul 19, 2006 | 12:19 PM
jiggaman's Avatar
so with a comptech / rt cat combo you had no rattles?
Old Jul 19, 2006 | 02:23 PM
Spoon's Avatar
Are you completely sure you didn't have a vibration with the RT cat?
Maybe it has something to do with the heat shield that surrounds the cat as opposed to the one between the cat and the body.
Is there a noticable weight difference between the RT cat and OEM cat?
Old Jul 20, 2006 | 06:50 AM
Yea with my RT Cat./ Comptech headers combo, I believe there was a very slight rattle when the AC is on, but goes away after a few seconds.
Yes I believe the RT Cat is lighter than the OEM.
Old Jul 20, 2006 | 08:36 AM
minkl81's Avatar
RT cat does not produce rattle at all. I had RT cat before the Comptech header and it was fine. But after getting the header on, it started to make noise.
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
