programing TSX 07 remote
Old Dec 23, 2010 | 03:18 PM
Jaan Lewaa's Avatar
when i purchased the car it came with only one keyless entry remote, n since i got LoJack in my car so I cant use key to enter in car i need remote to enter. However, i just purchased the remote from ebay but i dont know how tou program it
can anyone please tell me how to program it?? thanksssss
by the way my car is Acura TSX 2007
Old Dec 23, 2010 | 03:42 PM
PACman's Avatar
The key should mechanically open the door. Hmm....
Take the key, fob, and car to an Acura dealer to have it programmed. I've also been to Lock Smiths that can do it, but best to call around to confirm as well as get prices.
Old Dec 23, 2010 | 04:59 PM
Jaan Lewaa's Avatar
once I saw it here on this forum, but cant find it now. If its available here then y should I pay $90/100 to dealer
Old Dec 24, 2010 | 05:08 PM
RA032025's Avatar
in the 24th and a half...
Transmitter programing:
1) Turn the ignition switch ON (II).
2) Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless entry receiver in the power window master switch.
3) Within 1 to 4 sec, turn the ignition switch OFF.
4) Within 1 to 4 sec, turn the ignition switch ON (II).
5) Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless entry receiver in the power window master switch.
6) Within 1 to 4 sec, turn the ignition switch OFF.
7) Within 1 to 4 sec, turn the ignition switch ON (II).
8) Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless entry receiver in the power window master switch.
9) Within 1 to 4 sec, turn the ignition switch OFF.
10) Within 1 to 4 sec, turn the ignition switch ON (II).
11) Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless entry receiver in the power window master switch.
12) Confirm you can hear the sound of the door lock actuators with 1 to 4 sec, then push the transmitter lock or unlock button again, or the code will not be stored.
13) Within 10 sec, aim the transmitters (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14) turn the ignition switch OFF, and remove the key.
15) Confirm proper operation with the transmitters.
Old Dec 25, 2010 | 01:15 AM
Jaan Lewaa's Avatar
thanks a lot DD
Old Jul 5, 2013 | 03:39 PM
iSeeYouTwo's Avatar
Does the programming of the KeyFob also work for a 2004 same model ?
Old Feb 21, 2014 | 03:59 PM
indore's Avatar
This programming does not work on 2009 tSX, what's different
Old Apr 18, 2014 | 03:32 AM
chrismacmx's Avatar
7th Gear
Nice information
tsx_boy
Dec 13, 2019 08:33 PM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
