programing 06 tsx key fob remote
Old Jan 18, 2007 | 01:24 AM
jtru007's Avatar
programming 06 tsx key fob remote
i just got a replacement remote from ebay. do anyone know to program it or do i need to take it to dealer. i know its a simple procedure cus ebay also sell the instruction for the program. I thought i would try to find a free method first.
thanks
Old Jan 18, 2007 | 05:17 AM
moda_way's Avatar
I'll post them here because it could be used for searching, but they've been posted at least 5 times around here. I also corrected the spelling of the thread title.
Transmitter Programming
Storing transmitter codes:
The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the tailgate are closed.
1. Turn the ignition switch to ON (II).
2. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch. (located by the driver’s window switches)
3. Within 1 to 4 sec, turn the ignition switch OFF.
4. Within 1 to 4 sec, turn the ignition switch ON (II).
5. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch. (located by the driver’s window switches)
6. Within 1 to 4 sec, turn the ignition switch OFF.
7. Within 1 to 4 sec, turn the ignition switch ON (II).
8. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch. (located by the driver’s window switches)
9. Within 1 to 4 sec, turn the ignition switch OFF.
10. Within 1 to 4 sec, turn the ignition switch ON (II).
11. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch. (located by the driver’s window switches)
12. Confirm you can hear the sound of the door lock actuators within 1 to 4 sec, then push transmitter lock or unlock button again, or the code will not be stored.
13. Within 10 sec, aim the transmitters (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons.
Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch off, and remove the key.
15. Confirm proper operation with the transmitters.
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Oct 8, 2015 11:16 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
kixo
Sep 25, 2015 03:07 PM
