Problem: Grinding Sound when Turning Slowely - stops if you tap brakes
Ok guys I need some help, I have tried everything I can think of to fix this problem. It is my wifes car (06 TSX) all OEM.
When you turn right it sounds like their is a grinding sound from the front brake. If you turn the wheel to the left sometimes it will make the sounds stop. ALSO if you ride the brakes just a little bit it will typically make the sound stop. To add one more variable it only seems to happen when temps are above ~60 degrees. Here is the odd part, when driving I had my wife walk by the car and she says it sounds like it is coming from the rear driver side wheel (although now I think it is doing it from multiple wheels).
To better describe the sound, to me it sounds like the brake heat shield is rubbing on the rotor while it is turning. I already bent the shield back so it is 1/4" or so away from the rotor. Originally it would only happen when going slow around turns ~5mpg, now it will make the sound even at 15-20mph and is pretty embarrassing when driving in parking lots.
I can try to get a video of it, if it would help anyone better diagnose it. HELP! Thanks.
Brakes are brand new. It did it before the brake changes and it seems worse now. It's not so much a squeal but a low pitched grind.
Almost like a pad that is completely gone (unfortunately I have experienced that due to a frozen caliper) but not as harsh, if that makes sense.
I have never heard it happen in reverse.
I think I'm going to try to get a video in the next few days if it's not solved by then.
You should try to nail down front or rear first. My guess (semi-educated) is CV joint if it's coming from the front, wheel bearing(s) if it's coming from the rear. That's assuming whoever did the brakes didn't screw the job.
I think I'm going to take it all apart this weekend and look it over with a fine tooth comb. I still feel like its the heat shield rubbing the rotor as it turns (it sounds just like a piece of thin metal rubbing against something rotating).
I had this problem 3 days ago. The squealing was unbearable and only happened at slow speeds and in reverse. Forced me to take off the wheel, caliper, and rotor to see the heat shield rubbing where it shold be tucked in the middle of the rotor.
civicman86 (06-28-2011)
Thanks I will look into this. I swear it sounds like the heat shield, I juts haven't had time to rip it apart yet (this weekend as long as nothing comes up).
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
