Pre Painted fender?
Old Aug 30, 2004 | 02:40 PM
calitsx's Avatar
Pre Painted fender?
Does anyone know if you can buy a pre painted fender from the factroy for the TSX, I got into a little fender bend and just need a new fender.
Old Aug 30, 2004 | 03:19 PM
xizor's Avatar
Bye TSX, hello domestic?
dream on, you cannot buy prepainted body panels. I know, had my fender and bumper painted after an accident.
Old Aug 30, 2004 | 03:25 PM
blackjackman's Avatar
you cracked up you TSX ? when did this happen ?
Old Aug 30, 2004 | 03:34 PM
xizor's Avatar
back in april
Old Aug 30, 2004 | 03:44 PM
Dan Martin's Avatar
Photography Nerd
Unfortunately you can't just unbolt the old fender and bolt on a new one. The fender is welded in place so you have to cut the old one off and weld in a new one. Welding would destroy the finish so they don't bother to paint them from the factory.
Old Aug 30, 2004 | 04:03 PM
xizor's Avatar
didn't know that, i just assumed it was bolted on
Old Aug 30, 2004 | 04:20 PM
Dan Martin's Avatar
Photography Nerd
I could be wrong but I thought the TSX used a conventional unit body construction.
Old Aug 30, 2004 | 04:21 PM
calitsx's Avatar
Do you know why acura decided to weld on the fender instead of just bolting it on?
Old Aug 30, 2004 | 04:29 PM
Dan Martin's Avatar
Photography Nerd
We should probably double check to make sure it is actually welded but usually they do that in unit body construction because the body and the chassis are one continuous piece. It's cheaper to manufacture that way. The older cars used a body on chassis construction where the the body was assembled separately from the chassis and then they were mated together at the end of the production line. Still in that case most cars would have welded on fenders but some may have fenders you could unbolt.
Old Aug 30, 2004 | 04:56 PM
calitsx's Avatar
how much am i look at to get it replace and painted?
Old Aug 30, 2004 | 04:59 PM
Dan Martin's Avatar
Photography Nerd
I'm sure it will be $1000+ to get a new fender installed and painted. It's possible that they could just take the dent out and repaint it for a lot less. How much damage is there?
Old Aug 30, 2004 | 05:05 PM
calitsx's Avatar
no much at all the lady barely cliped but the fend had a dent that is the size of a soft ball but it is a little wrinkled up not a smooth dent.
Old Aug 30, 2004 | 05:11 PM
Dan Martin's Avatar
Photography Nerd
They still may be able to fix it. I'd take it to a couple reputable body shops and ask for an estimate.
Old Aug 30, 2004 | 05:13 PM
calitsx's Avatar
thanx alot for the usefull info.
Old Aug 30, 2004 | 06:21 PM
xizor's Avatar
your dent sounds like mine, just the front was bent in. they pounded it out and repainted, looks great, no need for a new one. and if some lady did it shouldn't her insurance be paying for it?
According to geico, reparing a fender is about 4.0 hrs labor, 3.7 hrs of painting.
labor is $36/hr, and paint is $24/hr, sooo
$144 labor + $222 paint labor/supplies comes out to $366.
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rhdune16
Sep 28, 2015 11:31 AM
jmaxima03
Sep 27, 2015 10:22 AM
