Power steering problem
Old Oct 15, 2014 | 06:14 PM
Violetm's Avatar
My old pump had broken seals so I got a rebuilt oem pump, replaced the pump took out the hoses and bolts and put it back together and now it's not working at all. The car is very hard to turn there is no power steering fluid running through the pump. I have also tried the bleeding system I have turned the wheels all the way to the left and the right and still I see no bubbles. Anybody know or have an idea of what to do?
Old Oct 16, 2014 | 11:01 AM
TexasHonda's Avatar
Unless you have a kink or blockage in one of the hoses on suction side, pump should push fluid. Appears to be a defective pump.
good luck
Old Oct 17, 2014 | 02:12 PM
mdkxtreme's Avatar
Does the ps pump squeal when you turn the steering wheel?
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
