Power seat and Memory seat - DOA
I checked fuses and looked under the seat as well. Can someone point me to what else I can check? Or at least verify what fuses I need to check? Maybe I missed one.
Passenger seat works fine,
Anyone?
I started checking connections I could reach. I guess next step is to actually remove the seat to start testing wires. Is there a relay or additional fuses under the seat?
in the 24th and a half...
At least fuses 7, 14, and 16 control the DPMS and its DTC storage.
To check for a DTC code...
Ignition off and move seat to non-momorized position
Press and hold Memo button and both memory buttons
Ignition switch on and wait at least 1 second, then release the three buttons.
After 1 second the two memory buttons will flash a code (the DTC)
1 x 3 second blink, no codes....
The first digit is shown by the number of 1 second blinks, the second digit by the number of 0.26 second blinks...then there is a 3 second break...and either a new DTC code or the same is repeated...
Report code here, and I'll read it off...
Awesome, cant wait to go try! Thanks duck!
OK, no light on the leds at the switch, check under-hood fuse #15 (40A) and underdash fuse #7 (10A).
Then check under-hood #23 (50A) and #20 (40A) plus underdash #21 (7.5A)...you already checked 7 above and 14/16 before. After that it's pull the switch to check values and/or replace the Power Seat Control Unit.
