Please post all 6MT problems here
I'm trying to compile a list of people who have any problems with their 6MTs.
My clutch is gone and to make it better I need new 1/2/3 synchros, 1/2/3 gears, and a new 1/2 shift fork. The details are long and involved, but to summerize I just need to see how many other people have had this issue.
If you could post them like this, that would be helpful to the readability:
Username : JoNnErD154
Year : 2004
Mileage : 25,100 mi
How Old? : 2.5 Years
Original Owner? : Yes
Problem(s): (1) Clutch began slipping at ~19,500 mi. (2) Executing a 1-2 shift @ > 4000 RPM grinds. (3) Under neutral load, 2nd gear pops out.
Year : 2004
Mileage : 25,100 mi
I got an 05 here on the brink of hitting 28,000 miles....no tranny issues, just the clicking clutch which reminds me to have the stealership take a look into at my next oil change. Other than that, tranny is still nice and smooth.
Originally Posted by sauceman
145,000 miles here. No tranny problems ever. Most awesome tranny I ever drove. In fact I just came back from a roadtrip in a Matrix XRS, and the TSX's is lightyears ahead.
Besides being extremely annoying, are there any other more serious issues associated with the clutch creaking / clicking. I have read many threads on this subject, but nobody seems to mention whether this leads to or is an indication of clutch failure. I have this problem on hot days (21000 mi), but I am not sure I want to rush out and have the master cylinder replaced.
I have a little over 30k miles on the TSX, and there is no problem with it.
Username : ians
Year : 2004
Mileage : 45000 kms
How Old? : 2 year
Problem(s): clutch clicking @ 35000kms
Problem solved after dealer replaced the master cylinder and the clutch assembly. Other than that no problem at all and the tranny is still as sweet as day 1. Oh, actually the whole car is even better than day 1.
Yeah! forgot to mention another issue.... I broke my center console when I tried to remove it to install the short shift kit and Acura didn't warranty it! :lol:
Year : 2004
Mileage : 45000 kms
How Old? : 2 year
Username : stewie20068
Year : 2004
Mileage : 31,000
How Old? : 2 Years
Problem(s): (1) heavily resists entrance into first gear when temp is <40 degrees. I have to stop at a stop sign and sit for about 2 seconds before the synchros work.
2) shifting 2nd to 3rd at greater than 4000rpms results in gear grind.
3)shifting from 1st to second at redline I will actually bounce off 2nd gear.
Basically my synchros have failed. However, I'm getting a new tranny under warrenty for the 3rd gear grind.
Year : 2004
Mileage : 31,000
How Old? : 2 Years
Year : 2004
Mileage : 31,000
How Old? : 2 Years
Year : 2004
Mileage : 31,000
How Old? : 2 Years
I have a problem with my MT: the car is way too fun to drive, and it's almost impossible to do under 80 on a freeway. I'm taking it to the dealer, they recommend replacing the car with a Ford Fusion under warranty.
Originally Posted by wickedk24
50,000 and the only issue I had was the creaking noise. Had the tranny fluid changed and it took care of that
hm... i will have to consider this...
I'll hit 20K this weekend and the only issue I've had is the reverse switch in the tranny that makes the rev. lights come on went out after about 10-12K. Dealer replaced it under warranty no problem. Other than that...tip top!
Originally Posted by xizor
30k miles, clutch is slightly glazed I believe, feels different than when I first got it, but doesn't slip. Transmissions feels great, no grinding
Originally Posted by vwong
I'm sorry but I just have to question you for your driving style. Maybe your driving style has something to do with these problems?
100% That is not normal. All 3 syncros don't just die out randomly.
Naw, it's not that I need all three syncros - only #2 is worn, but you buy the entire countershaft set with gears and synchros
My only problem is that I occasionally miss a shift into 6th gear, drop back into 4th from 5th then embarrass myself. If someone is in the car with me I act like I intended to downshift, but I doubt anyone swallows that bullshit. Oh well, at least it makes me feel better . . . .
I do find consolation in the fact that I am human.
The car, of course, is perfect.
No problems, had my 04 6MT since late '03, 36k miles, plenty of stop-and-go traffic. Just the clicking clutch that I should take to the dealer to fix. This is my first MT car also. I do change MTF frequently (10k to 15k miles), everytime I do that the shifter becomes silky smooth again. I recommend people do this more often than not, it won't hurt the transmission, and it's cheap if you know how to DIY (2-3 bottles of that stuff, less than $15
Year : 2004
Mileage : 31,000
How Old? : 2 Years
Year : 2004
Mileage : 31,000
How Old? : 2 Years
2)shifting 1st to 2nd at 7k+rmp is horrible slow even with VSA off and comptech quick shifter, just flushed the oil for REDLINE tranny fluid BUT SAME PROBLEM. I called several dealers asking if it was normal for the car to stumble and slowly react when doing quick shifts 1st to 2nd (2nd-3-4-5-6 are quick though) DEALER sead this was NORMAL, just the way the engineers set up the Synchros. I priviuosly owned a 1995 Integra GS 5mt with DCSports quick shifter EVERY gear had instantaniouse response under quick shift attempts. my last words are while racing the tsx theway 2nd gear is done costs me aboute .5seconds
Check out my other post...just had the whole clutch assembly replaced @ 28K:
https://acurazine.com/forums/showthr...1&page=1&pp=25
Originally Posted by CGTSX2004
Well, he has auto-x his car.
well i just told the dealer that I was grinding when shifting into 3rd at greater than 4k and that I had just had my fluid changed in the last month and they were like "well we don't open the transmission case, so we'll just give you a new transmission." And that's how I did it. Guess they figure normal wear and tear.
Really looking foward to having my transmission feeling like new again.
Username : Black_6spd
Year : 2005
Mileage : 17,500 mi
How Old? : 1 Year
Problem(s): (1) Clutch "click" can be felt and heard in two places during downward travel with an single click upon return. Most likely hitting cruise control and start switches. Had problem looked at by Weir Canyon Acura and problem only went away for 1 day. They said they "adjusted and lubed clutch."
It seems to get more noticable on hotter days, but could be a coincidence since I tend to be more pissed when its hot.
Year : 2005
Mileage : 17,500 mi
How Old? : 1 Year
All those with the 6MT and complaining of resistance to getting into 1st gear when stopped, just do this:
1) Press clutch
2) Count to 3
3) Put it into 1st
I bet it will solve over 1/2 the complaints.
1) Press clutch
2) Count to 3
3) Put it into 1st
1) Press clutch
2) Count to 3
3) Put it into 1st
1) Press clutch
2) Count to 3
3) Put it into 1st
Have the intermittent clutch squeal issue, and the clutch does click from time to time, but not lately.
At 16K, the tranny shifts like a dream, even more so since I switched to Amsoil full synth MTF.
Thought so. I glazed my clutch too two years ago at the track, it felt quite delicate for a while afterwards, but eventually came back to normal.
It just doesn't engage quite as solidly, though it does seem to be a bit better the last couple of drives. Either that or I'm just getting used to the new feel.
