Part next to glovebox ?
Old Oct 9, 2010 | 11:19 PM
limeybstrd's Avatar
While checking out my glove box for rattles I noticed the side part as per the image below.
Was wondering how this part connects? You can clearly see the gap on the pictures below.
The rubber weather seal is correctly in place, already checked that.
Old Mar 10, 2011 | 05:22 PM
kvan2007's Avatar
that's the fuse box cover, isn't it?
Old Mar 10, 2011 | 07:31 PM
Simba91102's Avatar
Old Guy
I'm pretty sure that what's known as "made in Japan ain't what it used to be".
Old Mar 11, 2011 | 06:28 AM
miner's Avatar
Ditto - UAW wannabees
Old Mar 11, 2011 | 08:57 AM
foc-us2k's Avatar
5th Gear
Its a end panel. There is nothing that a normal user would need to access behind it. It looks like yours may be off slightly. There are a number of clips behind it. You can try to remove it and replace the clips as needed.
The part number for your specific piece is:
77109-SEC-A51ZC
PANEL ASSY., INSTRUMENT (LOWER) *YR240L*
( LIGHT CREAM IVORY )
And the clips are:
90302-SA4-003
NUT, SPRING (4MM)
Quanty 2
csmeance
Jan 7, 2026 06:25 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Ny1718
Sep 11, 2015 09:21 AM
hand123
Sep 10, 2015 09:29 AM
hand123
Sep 10, 2015 09:27 AM
