OMG 2k for a headlamp
Old Dec 6, 2007 | 01:07 PM
robertico811's Avatar
Made4u2nV
Unhappy OMG 2k for a headlamp
I've been reading here a lot that some ppls tsx's have water in their headlamp and they've taken it to get serviced and it turned out to be some clips that needed to be changed. well yesterday i took my tsx to get that changed because i was having the same issue. they were very cool and said that they'll get that fixed asap. i waited for like 30 min then the rep came out and said it will not be covered because someone backed into my grill, not much but it did leave a lil dent. anyway when that happened the inside of the headlamp it cracked and left a whole about the size of a nickle and they said it was out of warranty and i had to pay $700 to replace the case or $2,000 for the whole light itself! i was like hell mf~ing no! for a hole that small that cant be. so i had him leave it like that. so i was wondering since the hole is so small is there any type of rubber compound or anything that i can use to plug that hole. you cant even see it just when you take out the headlamp. any ideas my fellow acura family?????
Old Dec 6, 2007 | 01:09 PM
moda_way's Avatar
I could've moved this for you.
I suggested getting your hands on a window chip fix-it kit from an Automotive store if the crack is that small.
Old Dec 6, 2007 | 01:37 PM
Joeydabomb's Avatar
In my eyes you have two options, if the hole is small enough you could always use some silicon and plug it or you could just get another headlight on ebay for under 100 shipped.
Old Dec 6, 2007 | 01:46 PM
ILoveMyHonda's Avatar
17781708
If the hole is small enough and not visible, I would first get all the moisture out by using a hair dryer.
Then, If the surface was flat enough, I would just seal the hole up with some water proof tape, or jb weld and call it a day.
But if that isn't the case, just buy a used headlight off eBay, there's a bunch.
Old Dec 6, 2007 | 02:04 PM
PACman's Avatar
Was the accident to the grill there prior to you servicing your car?
$700 for the headlight cover is over the top. I got one from a local Acura dealer for about $380ish. You can get one for $314 at this place http://www.acuraoemparts.com/delray/...All&vinsrch=no
Do your headlights work? (It's just the case that's broken).
Old Dec 6, 2007 | 02:35 PM
Made4u2nV
yea they work perfectly no prob, just water,moister in the case
Old Dec 6, 2007 | 03:11 PM
LukeaTron's Avatar
Where is the hole? If it's not on the clear part (doesn't sound like it) I'd probably just use a fiberglass patch. You'll want to rough up the plastic on the outside of the hole with some 150 grit paper so the resin has something to bite into. Overlap at least a half inch all the way around the hole. Let i cure for about 30 minutes and put another layer over it. That should do it.
Make sure you you get it completely dry inside first and throw one or two of those silica jell packets that comes with new shoes (and lots of things) in first. I think you can drop em in behind the reflector if you pull rubber surround off where the high beam bulb goes.
Did they at least put the clips on for you? That's like a 5 minute job at most.
Old Dec 6, 2007 | 03:48 PM
Made4u2nV
i dont even know if they even put on the clips. they made it seem that happened because of the hole thats there.
Old Dec 6, 2007 | 04:29 PM
LukeaTron's Avatar
Well yeah, if you have a big ass hole in the housing, water leaking in the seam between the clear and black parts is pretty irrelevant. However if you fix the hole, you're still going to want those clips.
Old Dec 6, 2007 | 04:45 PM
Made4u2nV
hopefully they'll give me those clips once the hole is plugged
Old Dec 6, 2007 | 11:09 PM
HI OFECR's Avatar
Ebay FTW
Old Dec 6, 2007 | 11:19 PM
TacoBellSauce's Avatar
time to get some JDM headlights
uzzmaan
Aug 4, 2025 08:29 AM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
Sep 17, 2015 09:01 PM
Glorygang600
Sep 5, 2015 01:17 AM
