No heat on driver side
Old Jan 7, 2014 | 10:31 PM
mau108's Avatar
Anyone run into the problem where the driver side vents are blowing only outside air?
Old Jan 8, 2014 | 02:12 PM
TexasHonda's Avatar
There is an auto-diagnostic system that can be accessed w/o Honda HDS. It is fairly complex and is described in shop manual. (automanualsource.com for $22). I think someone found a free download earlier.
There are separate blend doors for each side and blend door motor may be toast of pax side. If you can see under dash, you may able to verify no movement.
good luck
Old Jan 8, 2014 | 06:48 PM
mau108's Avatar
Checked the blend motor it's fine. And also ran the diagnostic and it came back blank (which means no dtc).
Any other ideas ?
rockyboy
Aug 4, 2024 10:35 AM
BoricuaTL
Apr 8, 2016 01:08 PM
01CLOwner
Oct 9, 2015 01:07 PM
sockr1
Oct 1, 2015 01:31 AM
mv01
Sep 15, 2015 10:36 AM
