No Clock, Radio, Circulation Displays
So, the clock, radio display, and circulation (heat/ac) display all went blank today on my 2004 TSX. I can still listen to the radio, still get heat, etc. I just cannot see what station I am on, or tell what tempurature I have the heat set to. I called my local dealer and was informed there is a "serivce notification" out for this issue. Apparently the fix is to replace the entire radio box. Anyone else having this issue? Seems like this should be covered under a recall if this has happened enough for Acura to issue a "service notification". Luckily I have the extended warranty which this is covered under instead.
Its a known issue. Check out these threads:
http://www.acura-tsx.com/forums/show...hlight=display
You're not alone, unfortunately.
dirleton
Aug 6, 2024 08:19 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
2004, acura, blank, ciruclation, clock, clockradio, display, information, radio, recall, rsx, screens, tl, tsx
see jlukja's post
