new clutch MC needed?
Old Feb 23, 2009 | 10:20 AM
Redline's Avatar
Just curious what you guys think...04 MT ~60k miles.
About a half hour into city driving, i start to feel a click/notch when i push in the clutch pedal in a little further than halfway...smooth through the first half of the stroke, smooth through the last half......this continues until its had time to sit for awhile
so im thinking its probably the MC...thought id see what you think before i go replacing things though...
thanks
Doug
Old Feb 23, 2009 | 10:30 AM
moda_way's Avatar
If you are feeling the click, that is "normal". Getting a new one won't necessarily stop it forever b/c folks have had theirs changed out and it did it again. If it is still shifting fine, then I would stick with it. Mine didn't blow out until I put a much stronger pressure plate on it.
FYI, it is a PITA to remove if you haven't read my DIY instructions.
Old Feb 23, 2009 | 10:50 AM
Redline's Avatar
so i should probably just sit on it till i cant shift into gear then huh? Maybe if im bored ill go pile some grease on the slave piston and see if that helps.
works for me...first nice weekend of spring saved.
thks
Old Feb 23, 2009 | 12:42 PM
moda_way's Avatar
Yeah, I'd personally sit on it. I rode mine out for well over 2 years before it finally failed.
cobra10363
Jul 23, 2024 04:13 PM
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
jamestheunderdog
Jul 19, 2016 07:58 PM
BigJilm
Sep 21, 2015 08:32 PM
heyitsvic
Sep 4, 2015 09:38 AM
