Need help.......is this normal, front bumper loose??? (pic inside)
Ok, heres the deal.........I posted this question a few days ago, but no one responded. https://acurazine.com/forums/showthread.php?t=19789
Anyways heres my situation, my front bumper was sticking out a lil (no flush w/ the headlight and ret of the car). I pushed it back in and heard a "click". Now in that same spot when I push on the panel a lil, it feels weaker then the other side.
Any suggestions???
****pic is not my car, I will take a pic if you guys want.
Any suggestions???
There are plastic clips molded into the bumper that lock onto a female type slot on the car - I removed my front bumper when I put on the Mugen front end and it just "unsnapped with a little pressure. By pushing it back in you just snapped it back in place. More than likely someone/thing applied enough pressure by leaning on the front facia which caused it to unlatch.
I agree that it took some pressure to take off the bumper - I had the same thing happen to me when I took my car in to get the alignment done after putting on different springs - the tech bumped the stop on the alignment rack when he pulled the car to far forward - put pressure on the air dam area and that pressure caused the facia to unsnap right under and behind the headlight
Can't wait to drive
I had that portion of the bumper on the driver side pop out also. This was after hitting something that bounced onto the bumper as I drove on the freeway. I popped it back in and it was fine.
Oakes
Wash & Wax
10-12-2015 11:17 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
robowarrio
09-01-2015 09:25 PM
