need help Maintenance Required Indicator
Old Jun 18, 2008 | 04:18 PM
cigahuy's Avatar
4th Gear
Need help reseting
Maintenance Required Indicator light
i follow these instructions many times
but it doesnt seem to work
Any advice?
Turn off the engine.
Press and hold the Select/Reset
knob in the instrument panel, then
turn the ignition switch to ON (II).
Hold the knob for about ten seconds
until the indicator resets.
Old Jun 18, 2008 | 04:39 PM
LukeaTron's Avatar
I had the same problem. Apparently the process is very sensitive to voltage fluctuations. Make sure everything is off before doing it - headlights, radio, HVAC, seat heaters, defrosters... everything.
Old Jun 18, 2008 | 04:45 PM
lcrazyaznl's Avatar
CL9 ABP
When you do the steps you need the press down on the brake then hold the select/reset button for 10 seconds when you turn it to II (on) position.
Then wait till it goes away.
Note if you don't want to reset your miles on bank a
set it on bank b
so it resets the one your not counting.
Old Jun 18, 2008 | 10:58 PM
cigahuy's Avatar
4th Gear
Thanks problem solved
good advice
problem was my cd player was on
i knew your lights shouldnt be on but didnt think cd player would affect
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
h22lude
Sep 27, 2015 06:22 PM
