need help! another gas mileage problem
Old Sep 17, 2005 | 11:54 AM
madmanmax3000's Avatar
Professional Newbie
So basically, a couple weeks ago I took a 120 mile trip from CT back up to Boston, at no time during the trip was there anything noticeably wrong, but as soon as I pulled into my garage my oil light went on. I had checked the oil probably three weeks prior to that, and the level was fine. I unpacked my stuff waiting for the engine to cool, and when I checked the oil, I couldn't even get a drop of oil to show on the dipstick!! Furthermore, a golden/brown substance was dripping onto my garage floor. I put in 2 quarts of oil and drove it about a tenth of a mile over to Valvoline (they had done my oil change about 6 weeks before the issue). When I got there my "Maintenance Required" light was on. They took about 15 minutes to do whatever they do and said not to worry the car was fine.
BUT NOW, and for the past couple weeks, I have been averaging about 18MPG when I used to average 24-26!! When I had an alignment done last week, the mechanic told me it looked like a bunch of old oil had pooled up around my right front control arm. My driving hasn't changed, if anything I've been taking it a bit easy because of gas prices. What do you guys think happened? Did I overheat and damage something? Should I go to the dealership and ask for help?
Any help would be awesome, hope she'll pull through
Old Sep 17, 2005 | 12:20 PM
JTso's Avatar
It's probably the wrong oil filter or it was installed incorrectly causing a leak. Did you check the drain plug? How much oil was put it? I can associate lack of lubrication and poor gas mileage...
Old Sep 17, 2005 | 12:31 PM
Professional Newbie
they said the drain plug looked okay at valvoline, although they had to put in I think 3 quarts. They said there was basically no oil in the engine. Should I call the dealership or will they try to screw me somehow?
Old Sep 17, 2005 | 12:43 PM
Howard911s's Avatar
HOWARD911S
3 qt? that is way too crazy for a 4 banger to burn that during the course of that trip, gotta be oil leak somehow.. if the oil pooled at the control arm, gotta be leak. Dealer? hm... u might be able to try to jack up the car. clean it very very well so no trace of oil leak is left. do a complete oil change, install everything using factory part... then take to dealer. hopefully they will just take it as is and take care of the problem... and hope their code reader dont show that there was no oil in ur engine and dont cover u
JTso's Avatar
If the wrong filter was installed causing the leak, and somehow the engine is damaged due to lack of oil, what do you think the dealer would say? I would at least install a Honda filter, then clean up the oil puddle before taking it in...
Old Sep 17, 2005 | 01:07 PM
Professional Newbie
any way I can prove to Valvoline that they were the cause of the problem? (assuming Acura tells me its the wrong filter)
Old Sep 17, 2005 | 02:06 PM
JTso's Avatar
Well, you need to determine what the problem is first... Is it the method of installation or the wrong filter. The wrong filter might have a incorrect size oil seal that causes the leak. Are you sure it's the filter where the leak is?
Old Sep 21, 2005 | 02:33 PM
Ellas9's Avatar
TSX: Boeing Dreamliner!
I agree, its the oil filter....either the wrong one or they didn't scrap the metal where the filter seal sits. They also probably either didn't fill with enough oil and put the wrong oil (5W20 - which tends to burn off in this car based on stuff I've read).
Get the garage to give you your $ back and tell them they're lucky the engine didn't seize. As far as your bad fuel economy, it could be all sorts of stuff...again ensure the correct viscosity of oil is in there (I would get a near 10mpg change in my old Accord when I had 10W30 vs. the required 5W30 in there). Hope that helps.
Old Sep 21, 2005 | 02:51 PM
JTso's Avatar
Another possibility is they left the old oil seal on the block, so the new filter didn't seal correctly.
Old Sep 21, 2005 | 03:48 PM
Professional Newbie
Yeah, a mechanic friend explained that possibility to me the other day....
I called Acura about 30 minutes ago and told them the truth (basically) and they are going to call me tomorrow with some more information. I hope it is a simple fix, but I'm going to bring it to the dealership this time because if they mess anything up, they will fix it for sure.
Can I get the dealer to use synthetic?? They will probably change my oil
Old Sep 21, 2005 | 04:14 PM
Viking's Avatar
Quattro in.....
Sure, you just have to bring the synthetic oil with you and instruct them to use the oil you brought.
Old Sep 21, 2005 | 05:06 PM
Professional Newbie
alright, nice, so how much oil does a full change call for?
Old Sep 22, 2005 | 09:13 AM
Viking's Avatar
Quattro in.....
I brought 5 quarts of Mobil 1 with me when I had the dealer perform the oil change.
Old Sep 27, 2005 | 01:35 PM
TSX559's Avatar
You might want to check the oil filter gasket. I had that experience once when i had my integra. forgot to take out the old gasket, then the next thing you know, oil was leaking everywhere. 5 qts of oil is about right.
OculiAquilae
Nov 19, 2018 02:24 PM
badboymn
Sep 20, 2017 11:08 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
PortlandRL
Sep 14, 2015 12:01 PM
Aleax
Sep 9, 2015 08:04 PM
