Navigation Bracket
Old Dec 30, 2003 | 01:49 PM
twanugolden's Avatar
8th Gear
Navigation Bracket
I tried putting a system in the back of the trunk but the Navigation Bracket hangs down too low. This forced me to move my system to the front on the trunk leaving no room for anything else. Is there any way to move the bracket up to leave room for the system to slide back?
Let me know...
Old Dec 30, 2003 | 02:24 PM
JaTe's Avatar
Jersey ---> Maryland
how big is the box? my box fits fine under there.
Old Dec 30, 2003 | 03:24 PM
Lung Fu Mo Shi's Avatar
Registered AssHat
Nice trunk tray.
Old Dec 30, 2003 | 03:27 PM
JaTe's Avatar
Originally posted by Lung Fu Mo Shi
Nice trunk tray.
haha...thats the all season mats my dealer threw in for free!
Old Dec 30, 2003 | 03:43 PM
e_lectro's Avatar
Still here
I found the braclet to be in the way when I built my box as well. Just head over to homedepot/lowes/menards/etc and get some metal and fabricate your own... Here is a pic of the one I made last summer.
It holds the DVD player up alot higher than the stock one. It you make your own, just make sure to add holes where the vents are on the DVD-Rom so it does not overheat or anything...
Old Dec 30, 2003 | 10:59 PM
8th Gear
What do you mean, "just make sure to add holes where the vents are on the DVD-Rom so it does not overheat or anything"
Where are they?
About how much did it cost you to make your own?
Old Dec 30, 2003 | 11:11 PM
e_lectro's Avatar
Still here
There as holes on the sides of the dvd-rom, you'll see them when you pull it out. They are to allow air to circulate through it so it does not overheat. If you make a new bracket that blocks these holes, the unit could die, and you don't want that.
A sheet of aluminum like i used might set you back in the neighbookhood of $5-$15 depending on size and local prices. I picked aluminum because it's easy to work with. If I had more tools, I would have used a stronger metal and made the bracket look nicer, but the cheap aluminum is holding up nicely.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
