my tsx pulls to the right
i was at shop to do alignment, every wheel is set to zeros. car is still pooling to right. back to different shop for check, again all wheels are at zeros, but car is still pooling to right, also did tire rotation it's the same. i have changed tires, put the winter set and it's the same pooling to right. replaced bushings, ball joints and it's still pooling to right. car has never been in to accident. what to do?
Most roads are crowned w/ a downward slope from L-R from C/L. This creates a bias to pull right. Camber settings are set to "offset" the road crown by 1/4 degree usually. That is the wheels are tilted slightly top to left (from driver's position) to offset road crown.
Do you have camber adjustments to allow custom camber settings? If not then "alignment" was for naught as camber was untouched by shops.
good luck
good luck
Peregrine
Jun 16, 2017 05:14 PM
Emily03
Oct 9, 2016 06:10 PM
