MID info button requires two presses to activate?
I've noticed this funny thing on my 06' tsx that I don't think is normal. My "i" button (top right button) on the steering wheel doesn't work the same way the manual says it should. Whenever I turn the car on, I have to press the "i" button twice (shows mpg, range etc) for the MID to turn on. Then from that point on when I'm using the button, it only require one press to make anything appear on the screen. If I shut the car off, I have to press the "i" button twice before anything appears on the screen and so on and so on. The button below it (shows trip computer, outside temp) only requires one button press to scroll through the info on the MID. It does not ever take two presses like the "i" key does. Has anyone else experienced this?
Mine does it in one push. Try starting the engine with the driver's door open - does the MID display "door open"? When you shut the door the normal MID upper half should appear.
FWIW, I've always been annoyed that I have to push the "i" to get the display back the way it was the last time I drove it. Crappy human factors design.
Originally Posted by b4ceen
same happens to me....2nd push works
Once in a while it'll happen on my 06. What's more common for me is the bluetooth button...sometimes I have to hit it 4 or 5 times before it'll give me the beep so I can give a command, or to answer an incoming call
These are old issues with threads about them. It's a bug in the programming, where the MID doesn't actually display unless there's some message displayed first, when you start the car. The message can be anything; service warning, door ajar, seat belt warning, DRL warning, etc. When the message clears, the MID will display as it should.
Not sure about the bluetooth issue. I get that sometimes, but only if my phone isn't really paired yet (which seems to take random amounts of time).
If it's software related, have people taken this to the dealership? I'm just surprised because I haven't seen this issue on here in a year. The two presses issue I mean. Most of this has to do with the screen starting out blank or not on the setting people left it won.
Make a hole, coming thru!
Once in a while, the MID doesn't activate on the first press, I thought because I wasn't pressing hard enough.
The "(i)" button is the knob below the temperature range, the one under the gas gauge is the "select" or trip odometer (and gauge brightness) control.
09-17-2015 09:01 PM
