maitenance light serviced
Old Jan 11, 2004 | 02:15 PM
LaxTSX's Avatar
Hi all,
I just had my car serviced (10K) and it was a whopping 140 dollars. I was thinking they were just going to turn off the light and change the oil. But anyways, I was reading the bill and it had a bunch of additives. Do you know if this is really needed?
MOA Oil Additive for 11.95
MI 3000 for 12.95
I have to admit that the car was alittle more peppy than perviously, but that may be because I just paid 140 and trying to justify. I was wondering if the additives gave the car that extra "power" or what did they do to make it drive better?
Old Jan 11, 2004 | 02:44 PM
Stevestr's Avatar
Looking at the '15 TLX
Re: maitenance light serviced
Originally posted by LaxTSX
Hi all,
MI 3000 for 12.95
That's it! I'm opening my own service shop so I can start jacking people around too.
Your 10K mile light is to change oil and rotate tires. How they slipped Oil Additives in is amazing. That's almost as good as the dude who really thought an oil change should be $60.
I'm telling you I should get in on this gig.
Just remember this. If you paid $140 for this simple service, imagine the bill when the 20K light comes on.
Old Jan 12, 2004 | 02:28 AM
The Mayor's Avatar
how do i get rid of that maintainence req light? do i just take out the fuel pump fuse for a bit? i disconnected the battery but it just came back on a few hours later
Old Jan 12, 2004 | 02:38 AM
Lung Fu Mo Shi's Avatar
Registered AssHat
I think you turn off the car, turn it to ACC with the RESET button held in and it resets. BUT...RTFM it's in there.
Old Jan 12, 2004 | 05:14 PM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
On Acura's you have the car off with the key in the "off" position. Press and hold both the "select" and the "reset" button(the ones you use to reset your trip., etc..) with both button's pressed turn the key to the "on" position- but not running. Continue to hold both button's and the light will go out in about 10 seconds. Do NOT let up on either of the buttons for the 10 seconds or until the light goes out and try to press them again quickly all you will do is reset your trip! I have not paid attention in my shop yet but all acura's seem to be the same in this regard, so I assume the TSX's are the same.
Old Jan 13, 2004 | 01:47 PM
XPLORx4's Avatar
My other "car" is a 4x4
The TSX has only one button for select and reset functions, not two. So you only have to hold down one button while you turn the key.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
oyayjoe
Jan 1, 2019 10:17 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
redsox68
Sep 16, 2015 06:18 PM
