loose e-brake... how to tighten?
Old Aug 2, 2008 | 05:33 PM
Worth's Avatar
today i parked my car on a slight hill and when i put up the e-brake up the car still rolled back. i park on this road all the time and have never had an issue. when i pulled the handle up there used to feel like there was some resistance but today it felt really loose and flimsy. cant i just tighten the cable and my problem is solved? anyone know how to tighten our parking brake? thanks
Old Aug 3, 2008 | 10:48 PM
narutobear's Avatar
i know on my accord its in the center behind the cup holders.. ill look for the tsx.. got service manual
Old Aug 3, 2008 | 11:39 PM
PACman's Avatar
One possibility - Check your rear brake disc & pads. It could be that your rear pads or discs or both have worn down that it's time to replace it. Less rear brake pad/disc will require pulling the e-brake higher.
Old Aug 4, 2008 | 02:24 AM
ThirdLane's Avatar
Isn't our E-Brake drum brake inside the disk hub?
Old Aug 4, 2008 | 09:30 AM
intensity2x's Avatar
If its suddenly loose, wouldn't that mean the cable snapped, or came off somehow? If it were worn brakes or just in need of adjustment I would think it would be a gradual decline in the tightness of the brake lever. Maybe I just understood the OP wrong but the suddeness of it would lead me to believe theres a problem.
ITSJESTER
17
Dec 6, 2018 02:29 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
jmaxima03
Sep 27, 2015 10:22 AM
Brandle34
Sep 23, 2015 07:20 PM
