Lights on center console out?
Old Jul 15, 2006 | 11:53 AM
BzeTSX's Avatar
Guys, I just bought a 04 TSX yesterday, with 46,000 miles. Anyway, the cd player was giving an erre code, and all the dash lights were out. The dealer I bought it from said that it was beacuse they changed the battery, I need to get the code from the Acura dealer. So, today I went and got the code, and drove around fine showing off my friends my new TSX, but I noticed as it got darker, that the lights in the center console still dont light up. Is this normal? BTW i guess I have less than 4K miles until my Acura warranty is up, do you guys reccomend the extended warranty in case anything like this happens and its something seroius? thanks!!
Old Jul 17, 2006 | 12:38 AM
jlukja's Avatar
Its a known issue. Check out TSB No. 04-021 in this thread: FAQ: TSBs, Recalls, and Known Issues
Get thee to a dealer before your warranty is up.
Old Jul 17, 2006 | 06:49 PM
BzeTSX's Avatar
thanks ill do that
Old Jul 25, 2006 | 04:02 PM
97AcuraCL's Avatar
My bolonga has a 1st name
mine has been replaced once, and they are now out again.
warranty is up...
i'm basically fucked.
They said they'd replace it if it was within a year of the part being installed, but of course it was exactly 13 months since it happened.
so here i am with a 3 year old TSX, and the dashlights have now been out 2x, now i just have to live with them out because acura wants $1300 for a new one.
son
of
a
bitch.
Old Jul 25, 2006 | 06:14 PM
jlukja's Avatar
^^ have you contacted the same dealer that replaced it the first time around? Maybe they can do it based on goodwill.
Old Jul 25, 2006 | 06:21 PM
shitbox's Avatar
same shit happened to me.. we're on the same boat..
i don't feel like buying an acura ever again.. well at least not a first generation acura.
warranty is up...
son
of
a
bitch.
Old Jul 26, 2006 | 02:24 AM
97AcuraCL's Avatar
yea i did take it back to the same dealer, too far out of the car's original warranty, and too far after the original 'first' replacement (refurbed) unit was put in.
i really wnana get on thier asses for putting a refurbed unit that arguably still had the same problem of the original unit. but i think it'd just be a waste of breath, it IS significantly after the warranty.
but i think its bullshit that a car's dash lights should go out once a fucking year.
i dont have the $1300 to repalce the unit, especially when i have no garuntee that even it will last past another year since its obviously a re-occouring flaw.
what i need to do is get brave enough to get up in the unit and see if i can fgiure out if its just bulbs, or what thats casusing the lights to go out often.
Old Jul 26, 2006 | 03:45 PM
seurat's Avatar
7th Gear
Same thing happened to my 04 TSX after about 1.5 years of use. They had to replace the entire center console, including the navi and CD changer. Never did get my old CD's back (the ones I accidentally left in the changer).
Old Jul 26, 2006 | 04:04 PM
jiggaman's Avatar
I spend 2 much time here
for such a wide spread issue its bull shit that you should even have to be under warrenty
Old Jul 29, 2006 | 03:04 PM
TheHardlyFast's Avatar
I'm also pissed at Acura about this issue.
I just recently had a case of the 04-021 and it cost the dealer actually $1700 and some change to get it fixed.
Old Jul 29, 2006 | 05:37 PM
JdmStyle's Avatar
Try my method..
https://acurazine.com/forums/showthread.php?t=32476
Old Jul 31, 2006 | 08:41 PM
BzeTSX's Avatar
just got the TSX back from the dealer with a new stereo....lights work...fixed under warranty and got a RL for the day...nice!
Old Jul 31, 2006 | 09:19 PM
jlukja's Avatar
Make the check out to jay-luk-ja.
j/k glad it worked out for you.
Old Aug 3, 2006 | 10:46 AM
llJrockll's Avatar
Rebourne
Does anybody, know the the affected VIN # range?
by the last 5 digits of my VIN it looks like I am around the 500th built TSX...
at night, I could notice it slightly dim....I would like to get this fixed, if indeed there is a problem. I also notice sometimes that my Nav unit is slightly dimm, when the car starts.
Thanks.
Old Aug 3, 2006 | 11:19 AM
jlukja's Avatar
Thanks.
Its in the TSB, in the same line as the date. "Applies to 2004 TSX From VIN JH4CL9...4C000001 to JH4CL9...4C028982"
Old Aug 3, 2006 | 12:49 PM
llJrockll's Avatar
Rebourne
Okay, I see it now...I wasn't able to see it at first because it was so small, so I guess I'm included in one of these recalls. I think I better check out other TSX's and see how their Lighting looks (since I can't really compare yet). If it's much brighter than in mine, then I guess it's time for me to take it in to the dealer and have that fixed.
Thanks...
J
Old Aug 3, 2006 | 07:47 PM
97AcuraCL's Avatar
please see this thread for a potential solution, i need to actively figure out a way to fix this:
https://acurazine.com/forums/showthread.php?t=32730
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
bymotion
Nov 18, 2015 11:28 AM
PortlandRL
Sep 14, 2015 12:01 PM
