leather issue
101 years of heartache...
leather issue
i was going out this morning to pick up my dad's dry cleaning this morning when i found something. On the left side of the bottom of the driver's seat, where the perforated leather ends and the traditional leather starts, i see some wrinkles. that was just fine, thats normal, but not small tears in the leather! they are very small but obvious cuts it seems in he same line of the wrinkes. if you look at it its like someone took a small swiss army blade and made quick slices at the leather. if i remembered right there were 2-4 of these cuts. my dad says were taking it in to the dealer, but can they do anything about and is it covered under the warranty?
thanx
thanx
First, it isn't leather, it's vinyl.
I have lots of wrinkles in that spot because of getting in and out of the car and it is more shiny than the rest of the seat because of the rubbing. It stands out quite a bit and bothers me a little (the longer I own the car the less crazy I seem to be about the problems I have).
Explain the "cuts" better. How long, how deep?
the cuts are not very deep, not very wide. they are about an inch long. again, it seems like someone lightly sliced at the material with a small jackknife. thanx 4 the responses
Sorry, I don't know the answer, but please let us know what the dealer says..
Again, that part is vinyl. The only real leather on your seats is the strip with the perforation in it.
Is it truly a cut or is it what I see on mine that I would characterize as a wide crease with tiny creases in it. Can you spread them wider?
My CG Qtrz 6sp non navi is 1 month old and I just discovered a small tear in my back seat like the ones you are mentioning. It is a very fine tear, about 1 inch long, between the perforated holes. Definitely not caused by me (99% sure), it looks like it came that way from the factory (very fine tear, a straight line between the holes, hardly visible)-
Curious as to the cause, the fix, or if it is ok to leave as is (if it does not worsen)-
yea that is exactly what i was talking about. i where flush, non jagged clothing. im not one of those rocker punks with chains and metal objects hanging all over lol. but anyway, thank you for the feedback, when i get to the dealer and recieve the news, ill let you guys who are interested know.
Luke 1:37
Ok, so I should get vinyl maintenance products to use for the vinyl part and leather maintenanace products for the perforated leather parts. Ok, just to make sure, the only leather in the car is the perforated areas?
VV "Precision Crafted" VV
Sigh.
We have this debate every month. There is no official word.
1. All agree that the perf area is leather.
2. Some think the rest of the seating surface (the "thick" non-perf part) is leather as well. I'm in this camp based on my experience with detailing my seats and how they handle the products I use.
3. All agree that the sides and back are Vinyl.
So use Leather on the perf and Vinyl on the back and sides. Decide for yourself what the non-perf thick areas are and use what you want.
There is actually an official word on this. I wrote to Honda Canada via the owner email function on the Acura.ca web site. They told me that the only leather in the car is the perforated stuff. Everything else is vinyl. I saved the original email if any still doubt.
Also, I then wrote to one maker of car care products, though some of you will probably tell me that they are bad car care products. Anyway, the folks at Armor All say that you can use their leather protectant spray even on the vinyl areas, and that it contains the same UV protectants, etc. This makes it much simpler: One spray, one rag, etc. The only disadvantage is that it costs more, because it also contains leather nutrients. Also it has a lower shine, but that is an advantage in my opinion.
Here we go again ...
Regardless of any official word, I'll take the expertise of a leather and vinyl repair person with 15+ years of experience who had to repair my dashboard on my 04 after a dealer "incident" during radio replacement:
- All the main seating surfaces, both perforated and solid, are leather.
- The sides, back, and bottom skirts of the seats are vinyl, as is the top of the center console.
- All of the front headrests are covered in leather
- As I recall, only the front facing of the rear headrests are leather, the rest of the rear headrest (which is the top of the seat) is vinyl.
- The leather is pigment coated, part of why the difference in appearance is subtle.
This repair person showed me how he can tell, confidently -- the leather and vinyl respond differently when pushed with a fingertip, there's a distinct difference in feel and appearance (to him, and to me as well). Try it yourself! (On my car, the leather is noticeable stiffer, and flex lines are different).
Why do I bother putting this in the forums again? You need to use leather conditioner on the leather to keep it in good shape over time. I second the comment that the surfaces respond differently to the leather conditioner or vinyl cleaner.
Originally Posted by jerzpwr
wow i just hate when that happens to leather seats. kinda reminds me of cheap mustang leather seats.
Just be sure to use lexol on the perforated portions and 303 protectant on everywhere else.
Regardless of any official word, I'll take the expertise of a leather and vinyl repair person...
i think whatever your body touches in the seats is leather. I had vinyl seats in a Jeep and they didnt wrinkle like the leather on these seats do. Every car i had with leather did wrinkle. I think if its not wrinkled its vinyl. Seating surfaces are leather everything else, vinyl
Hmm. So the people who answer the email for Acura.ca are misinformed? I'll check with them again.
But another question: Why would knowing exactly which parts are leather really matter? Since you can use a leather protectant on the vinyl parts of the seat too (at least according to one manufacturer of these products), it would be safe to treat the entire seating area as leather, right?
Originally Posted by MarkPinTx
The entire seating area of the TSX seat is leather, not just the perforated parts.
Originally Posted by STL
Based on the leather in my S2000, I think that is correct. Some people have incorrectly interpreted that only the perf'ed part is leather.
Originally Posted by cconrad
How could I incorrectly interpret what Acura told me outright? Anyway, like I said, what does it matter.
Apply leather products to it all; it won't the vinyl bits, right?
I think the TSX has a full leather seating surface because:
1) that's how it is the S2000
2) vinyl doesn't wrinkle like leather and people are seeing the non-perf'ed areas wrinkle
3) why would Honda use two different vinyls to cover the seats
4) making only the perf'ed part leather seems rather silly -- if you do that you might as well make the entire surface vinyl
...exactly how did you phrase the question and what exactly was their response? ...
Here is the answer:
Originally Posted by Honda Canada
-----Original Message-----
Sent: Tuesday, July 19, 2005 10:05 AM
To: Chad Conrad
Subject: Vehicle features
Good day Mr. Conrad:
This will acknowledge and thank you for your e-mail regarding your TSX. We are sorry for the delay in answering your questions.
We can advise that the seating surfaces(the perforated ones) are leather, the other ones are vinyl
For cleaning the leather, ...
To: Chad Conrad
Chad
Can't wait to drive
This has been discussed ad nauseam in these forums.
Perforated parts of seats: Real Leather
side bolsters of seats: Synthetic leather (but it's not vinyl)
backs of seats: vinyl
Someone stole "My Garage"
And I am 99.99% sure from my car, that the perforated AND bolster areas are real leather. The sides (facing door or console) are vinyl. Look at the seam -- DEFIANTELY two different grains (leather, vinyl). Also, the pure feel of the two areas, and the way that vinyl is stickier/thinner feeling, is a sure sign that the outer sides are vinyl, the bolsters and perforated areas are leather. I'd bet good money on this if someone wanted to do an experiment.
Registered Abuser of VTEC
Synthetic leather is made from polyurethane, while vinyl is made from polyvinyl chloride (or more commonly, PVC). They are similar, but not the same
FWIW, I've never seen a leather seat that didn't have leather "seating surfaces," meaning that whereever you park it, the parts that touch you are leather. My Integra has leather seating surfaces as does my mother's TL-S. A lexus LS430 has leather just about everywhere, as far as I can tell.
Here's a product to make it easy to do since it protects both with same product...
http://www.properautocare.com/blinpr.html
Wow, now i'm confused more than ever. If the bolsters are leather, I'd like to use leather conditioner on there just like i use on the perforated surfaces instead of just 303 like i do with the other vinyl surfaces.
I have an '05 tsx with parchment color interior. I have a problem with the lower back of my seat being discolored. I think this may be due to silk slacks that have not been dry cleaned yet.
I have tried using Lexol cleaner. It is effective on all but the area that I just mentioned. Is there anything better than Lexol that I may can use?
I don't want my new car to look old!
By the way, here is the latest in my attempts to see what Honda/Acura knows:
_____________________________________________
Sent: Wednesday, July 27, 2005 10:35 AM
To: Chad Conrad
Subject: Question to Acura re. leather (dye method and which parts are vinyl)
Two questions: First, I understand that leather can be either vat-dyed or spray-dyed? Which kind is in the TSX?
Second: Sorry, for bringing this up again, but I'm getting conflicting information. You previously told me that only the perforated sections in the TSX are leather, and that the rest is vinyl. However, many other TSX owners out there are saying something more like what I have pasted below. Can you reconfirm with those involved in manufacturing (or procurement, or whoever) who would really know? Again, take your time in answering, as I value an accurate response over a fast one. Just let me know if you're working on it.
Everything following is a quote from https://acurazine.com/forums/showthread.php?p=449982#post449982
(and then I quoted that post)
To: Chad Conrad
Sent: Thursday, July 28, 2005 2:20 PM
To: Chad Conrad
Subject: Vehicle Features
With respect to the seating surfaces, we have advised that the perforated ones are leather, the other ones (lateral, side, and back) are vinyl. A portion of the headrest is also leather. Honda is supplied with these components and we do not have additional information available regarding the manufacturing process of the leather parts.
Yours very truly,
ACURA, A Division of
HONDA CANADA INC.
Philip Ofenberg
To: Chad Conrad
Yours very truly,
HONDA CANADA INC.
Philip Ofenberg
Sent: Friday, July 29, 2005 8:33 AM
To: Philip Ofenberg
Subject: RE: Vehicle Features
Philip,
Thank you for your quick response.
Just a few quick follow-up questions and then I'll try to stop bugging you:
Re. the leather -- Why, then, do the side bolsters (I assume this is what you mean when you refer to the lateral pieces) have a distinctly different appearance and feel than the obviously vinyl side and back pieces? C'est-à-dire, the non-perforated parts that touch the body still seem to be more like leather than like the side and back pieces, especially when you poke them with your finger and examine them closely. Are these pieces a different kind of vinyl (PVC), or maybe a kind of urethane instead of PVC? Are there perhaps three different materials covering the seating instead of two?
To: Philip Ofenberg
Philip,
FrankO
My Dealer Replaced My Drivers Seat, Seat Leather.
Originally Posted by Proo
So it sounds like it just wore out due to usage? Is there anything out of the ordinary about how you use the car? Do you have pointy things in your pockets or wear hockey gear while driving?
Plastic is
All this confusion arises from the fact that car companies charge extra for leather, leading people to believe it actually costs that much more. The fact is a high quality vinyl such as "IZIT leather" is almost as costly. Plastic is an engineered material and cost varies tremendously. High quality plastics wear as well leather, breath well and are far more resistant to sweat and stains. It is not necessary to use such high quality multi-layer plastics in low wear areas, so less expensive formulations are used to reduce costs for areas such as seat behinds.
The plastic leatherette in BMW and Mercedes is superior to leather in most ways, except for traditionalists who are willing to pay more for a natural material, even though it is highly processed and full of nasty chemicals. It has a certain smell, unmatched by polyurethane. Leather starts to wrinkle with age, and looks clearly different. Some enjoy that genuine leather look, it implies wealth and luxury. Many treated and colored leathers dont breath any better than plastic, the reason perforated leather is used. Both should last the life of the car without any further treatments. Only cleaning with a damp cloth is needed. Spend your car fluids money elsewhere.
I read a PR release from Acura saying they dont use vinyl in the TSX. Ive noticed the new car vinyl off-gas film that developed on my other cars on the inside glass surfaces
isnt appearing on the TSX. I breath better knowing that.
What you say about using different quality levels of plastics in different areas makes sense. Here is what Philip at Honda Canada told me in his most recent reply, further to my post #37 above:
However, he continues to use the word vinyl. Are you suggesting that the covers are not vinyl, but some other plastic? (And what about the dash, etc.?) It seems the engineers don't tell the PR people much.
Sent: Thu 8/4/2005 1:08 PM
To: Chad Conrad
There are different types of leather and vinyl used for the seat covers, as some parts will have to stretch more than the others, and will incur more tension over their surface and at their stitching points.
Yours very truly,
Philip Ofenberg
Customer Relations Specialist
ACURA, a division of
HONDA CANADA INC.
To: Chad Conrad
Yours very truly,
Philip Ofenberg
HONDA CANADA INC.
