Knuckle Hub assembly...
Old Jan 19, 2016 | 10:23 AM
jabbar's Avatar
So I just recently purchased a new bearing hub and knuckle....does anyone have experience pressing these parts together. I'm thinking the bearing must be pressed in thru the front of the knuckle followed next by the hub....is this correct? Once I have everything assembled I should be able to install this as a unit with relative ease...
Old Jan 19, 2016 | 11:45 AM
TLer trash's Avatar
Typically, you press in the bearing, install a snap ring, swap the tin shield over, and then press the hub/flange in.
Old Jan 19, 2016 | 11:58 AM
jabbar's Avatar
Ok thanks next I need to find a press I hear napa near my house has one ....
Old Jan 19, 2016 | 07:00 PM
kbh's Avatar
kbh
I installed mine with a 4lb sledgehammer.
gavriil
Apr 1, 2026 12:45 PM
jabbar
Jan 19, 2016 08:17 AM
