injen intake
Old Apr 27, 2007 | 08:14 PM
on3_mike's Avatar
injen intake
okae... when i drive i can hear my injen intake and it sounds great.... only until 6000 rpms... anything over that the intake makes a horrible sound ... a sound like something is grinding... is this normal?
Old Apr 27, 2007 | 11:23 PM
clee109's Avatar
I Quit
injen vibrates a bit over 6K making that sound, it's normal according to Injen and I haven't had an issue with mine and it makes the same sound
Old Apr 27, 2007 | 11:41 PM
taylor314gh's Avatar
04 A-Spec TSX navi
you also have to remember that vtec kicks in at 6000, which changes the engine sound. I can hear it very loudly through my injen intake
Old Apr 28, 2007 | 06:08 PM
//TypeS//'s Avatar
I get my Injen Cold Airintake this week. I hope I can hear then that I installed an Injen CAI. My transmission is automatic.......
Will it make a better sound when you compare it with the original?
My ride is an Honda Accord 2.4 Type S (EUR)
Old Apr 29, 2007 | 02:35 AM
sluggercz's Avatar
It makes a much better sound. I would check your vibra-mounts mike. They are those rubber pads that screw on. I made sure mine were very tight fitting. Also check to see if the washer is above the metal part as it should be. IMO once you rev past 6000 RPMS the injen sounds even better. Also, check you seals where the down pipe meets the standard intake tube. You might need to retighten the clamps
Old Apr 29, 2007 | 07:57 AM
//TypeS//'s Avatar
Thanks sluggercz!
Old Apr 29, 2007 | 06:36 PM
sluggercz's Avatar
np
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
