How to bring up CODE on radio display?
Old Nov 2, 2012 | 12:24 PM
TSX_driver's Avatar
Exclamation How to bring up CODE on radio display?
Hi guys
I have a 2005 TSX with Navi.
I brought in my car to the bodyshop recently and they must have unplugged my battery and now my radio doesn't turn on.
I have the code but I never have the option to put it in.
I read that by disconnecting the battery and re-connecting it would come up.
I tried by disconnecting only the right side of the battery but that does not help. Should I disconnect both sides?
What should I do?
I can't drive without music
HELP
Old Nov 2, 2012 | 02:06 PM
RA032025's Avatar
in the 24th and a half...
If they tried to enter a code too many times, the system locks out.
Other possibiility, check under-dash fuses 6 and 32.
Old Nov 2, 2012 | 02:15 PM
TSX_driver's Avatar
Thank you but I figured out how to do it.
You have to use the right knob on the radio (station select) to move the numbers 1-6 and then click on the button again to select the right number and continue with the rest to put in the code.
Old Nov 2, 2012 | 02:25 PM
swoosh's Avatar
takin care of Business in
^^^ THIS !!!
they might have tried entering the code many times....
but either way, disconnect the battery for 15-20 minutes....and check the fuses in the meantime...
Old Nov 2, 2012 | 03:18 PM
TSX_driver's Avatar
I forgot to mention that I did it and it worked. No need to disconnect the battery or check the fuses.
I don't think the mechanics even bothered with trying to fix my radio again.
TypeS860
Jan 10, 2026 11:11 AM
Puma Jim
20
Oct 20, 2016 11:59 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
