Hissing in the cabin
Old Dec 17, 2013 | 09:57 PM
mau108's Avatar
Hey guys getting this hissing in the cabin. If I turn the steering it goes away but if I let the steering be it comes back.
Check out the video below and let me know what your thoughts are. Thanks
Old Dec 19, 2013 | 04:33 PM
npolite's Avatar
PS fluid level looks ok?
Old Dec 19, 2013 | 07:20 PM
mau108's Avatar
Yes and I just did a flush of the ps fluid too...sound is still the same
Old Dec 19, 2013 | 08:31 PM
mau108's Avatar
MY dad and I did some troubleshooting and think it may be the rack and pinion.
Old Dec 20, 2013 | 06:58 AM
miner's Avatar
R&P are a known issue in Gen1 cars. I had mine replaced @32000 in my '08.
Old Dec 20, 2013 | 05:49 PM
npolite's Avatar
If it indeed is the R&P, get it diagnosed and then get a hold of Acura client services. This should not be failing at 135,000km ~85k miles.
Old Dec 21, 2013 | 08:06 AM
TexasHonda's Avatar
Check whether any bubbles are returning to reservoir when the hissing occurs. If yes, air is getting into PS fluid on suction side somewhere; inlet fitting, hose connection, reservoir connection, PS pump shaft.
good luck
Old Dec 21, 2013 | 03:22 PM
mau108's Avatar
well this is weird. My mechanic replaced the passenger side drive shaft (axle) and it fixed both problems I had. Vibration while accelerating and the hissing sound in the cabin.
Weird. Either way this problem is now fixed.
Old Dec 22, 2013 | 09:31 AM
npolite's Avatar
There isn't anything in the axle that would cause a hissing sound. I still suspect you have an issue with something in the PS/R&P.
Keep an eye on it and like TexasHonda said, see if there are any bubbles in your PS reservoir.
Old Dec 27, 2013 | 12:07 PM
mau108's Avatar
argh it's back! Vibration is not there any more while accelerating but the hissing is back.
I may just live with it for the winter and take a look into it in the summer. I also have a problem with the driver side vents not getting heat and passenger side getting heat.
I bought a car with problems, meh got the car for cheap so not complaining.
Feb 25, 2020 09:57 AM
vpasla1
Sep 17, 2016 07:24 PM
LeVeL
Oct 18, 2015 04:19 PM
merc009
Sep 29, 2015 03:06 PM
