HELP: Remove the Intake Manifold to access Starter to Replace Engine Battery Wire (+)
Old May 21, 2012 | 04:56 PM
Justin7894's Avatar
Question HELP: Remove the Intake Manifold to access Starter to Replace Engine Battery Wire (+)
Does anyone have experience removing (or dislodging) the Intake Manifold (08 TSX auto/nav) in order to access the starter?
I've removed the two nuts and 3 bolts, disconnected the air hose, removed the oem intake tubing from the throttle body, removed a throttle body air hose, and a couple hose connectors and wire harness connectors.
The problem is, I cannot pull the manifold away from the fuel rail/head on the throttle body side. It's possible that the two coolant hoses that feed into the throttle body need to come off, but before I do that, is there anything else that needs to be unbolted?
In the images below. The items squared in green have not yet been removed/disconnected. Are these a must for moving the IM enough to access the cables going into the starter?
Any tips for pulling off coolant lines without draining the coolant?
How do I access the stuff in the back of the IM (see pic #2)
Thanks!
Old May 26, 2012 | 12:19 PM
TexasHonda's Avatar
You must have seen the DIY posted on this forum. Clearly the coolant lines must be removed. Either drain coolant or pinch hoses w/ vise grips and then release.
If you don't have a shop manual suggest getting one.
good luck
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
kmarqueling
Oct 3, 2015 01:14 AM
Phambam12
Sep 6, 2015 06:57 PM
EvilVirus
Aug 31, 2015 05:24 PM
