Help! Gas mileage suddenly went bad ...why?
Car is 2004 TSX, AT with Navi with 60k miles.
On the last tank of gas, with 80% highway driving the car needed a refuel only after 270-280 miles. The on board computed showed avg. of 22 MPG.
There are no check engine or any other lights on. Car "feels" and drives normal.
Driving style has NOT changed at all....since my wife is the only person driving it.
She always gets at least 26MPG or better. When i drove it, i got 24MPG or better.
This time, just by looking at the gas gauge, i can tell that gas goes much faster.
What could be the reason for this drop in MPG?? Car is well maintained. Good brakes, fresh fluids, new tires, premium gas, no leaks - we keep up with the maintenance.
What should i look at? Is it worth it to plug it to an OBD II scanner even if there is no check engine light on?
Could it be just a tank of "bad gas"?
Has anyone had this issue happen to him/her?
Thanks!
Thanks!
I've also noticed lower gas mileage lately. There have been a few conversations about the effect of Winter Gas
I'm not sure if thats the only cause but I'm as curious as you are.
Originally Posted by LuvMyTSX
Are these new tires the OEM Michelins or another tire? Some tires can lower mpg slightly. This happened with my Bridgestones.
Well, a lot of things can lower mpg. Yours isn't all that significant so I wouldn't be concerned just yet as long as it's driving normally. Maybe you idled it a little longer, sat in traffic a little longer, drove it harder a couple times, etc. There are just so many variables that could lower the mileage, including colder temps and winter gas, as mentioned above.
Originally Posted by DurgyNess
Check air filter, when is the last time you've had an oil change? check oil.
Both of those decrease mpg
Oil is almost 5k miles old - also to be changed this weekend. I use Mobil 1 Synthetic.
As you can tell, both of them are not that old.
Originally Posted by jlukja
Have you checked your tire pressure?
I've also had reduced fuel economy over the last 2 tankfulls. from 27mpg to 23.5mpg. Weird.
Have you made any changes like this?
...you've only dropped 2 miles per gallon you may regain it after this
(If you're keeping your car maintained on schedule, an oil change isn't going to make a perceptible difference unless you do something like switch to synthetic, and even then it will be marginal...)
Winter mileage
Some of it might depend on where you live...in the Northeast (and Northwest, I believe), we get that wonderful 'oxygenated' gas, which sucks. You get poorer mileage AND performance for the same, or greater, cost...whoopee!
Also, note that Sunoco is now using a high percentage of ethanol in ALL of their fuel, again most specifically in the Northeast. Ethanol provides higher knock resistance (octane rating) but has less energy by volume compared to gasoline, so you will ultimately get poorer gas mileage (probably less power, too).
I have noted a 2.5-3mpg difference when using Sunoco fuel compared to Exxon or Shell.
Os.
Os.
Thanks!
Thanks!
Try picking up a couple of bottles of fuel injector cleaner first and see if that helps. If not, move on the sensors.
Thanks!
Thanks!
Assuming you put 13 gallons when you filled up, that's 24 - 29 mpg. Pretty much what should be expected for those conditions.
I've gotten just shy of 500 miles out of a tank on long highway trips. I forget how much exactly I put in but when I crunched the numbers it was a little under 38 mpg. This car just sips at gas properly coaxed to do so.
Here is an update....
After 2-3 tanks of gas, oil change, new air filter and fuel injector cleaner - gas mileage is back to normal! We are getting 23-24MPG on mostly city driving and 28-29MPG on the freeway doing 75-80mph. It's been good for the last 4 weeks.
Not sure if the fresh oil/air filter were the reason for the improvement or it's due to better gas from the pump.
Hi there, I had a similar problem twice so far with my 2006 TSX, the first time I notice it within 3 or 4 days and I track it down to a tire with low pressure due to a nail on it, after fixing the tire all went well for several month until about 5 weeks ago when I notice about a 20% decrease on fuel consumption with no apparent reason, it went like that for about 3 weeks when it just got back to normal without me doing anything other than checking tires and the usual checks (It had being service about a month earlier). I notice the change after putting gas at a Costco gas station in Seattle, it was not the first time I fill up there, but the first time this happened to me, I think either that was a bad batch of gasoline for whatever reason, or I had some dirt on a filter that finally dissolved or something, its being 2 weeks with excellent gas mileage as it usually is.
A mystery as I'm the only one that drives my car and I'm pretty regular on my driving style and the places I go to in town.
All, I don't know what the conclusion of this thread was. I stumbled upon this while trying to figure out why my TSX's fuel economy dropped. I just replaced 2 of the OEM Michelins with Yokohama avid 4S. That seems to the culprit!!
Yokohama avid 4 s tires
my acura is running high on gas too....WHY!?
i just bought my '04 tsx about 2 months ago @ 84,000 km. did an oil change as soon as i bought it with pennzoil platinum full synthetic and tire rotation/alignment. i've also been using 91 octane fuel. but i'm only getting about 400km for every tank! (60%city driving) is that normal? it feels like its using gas too fast...
i used to own a z24 prior so i dont know if its that comparable but even my cavalier got much more gas mileage then this one!
should i do a tuneup? or could there be a bigger problem here?
thanks for any advice!! ** I do love my TSX tho, she's a beauty!**
i live on the west coast of canada, and we've actually had quite the mild winter (you could probably see all about it on the net with how our olympic mountains are lacking snow :P ) so i didnt factor that in with my gas consumption
i guess i'll keep an eye on it as the summer approaches...
I have a 2004 Milano Red TSX that I just got a month ago. 69,000 miles and have had some very different MPG from it. I think mine are from cheap tires the dealer installed and I didn't pick up on until reading this thread. They are ZR Raptor by Riken Tires. I will keep them until they wear out...I expect fairly soon...
On the gas milage side...Costco gas has methenol in it up to 10% and I have avoided it because it does reduce gas milage in my other car..2002 Accord EX. I have been running 93 octane in my 2004 TSX and have found gas milage vary...from 25 to 28 mpg with my foot out of it. Most of the driving I do is 38 miles one way to work and mostly freeway in Mighigan. The cold does seem to make a difference to...less mileage. I am glad to not be the only one out there that has seen shifts on daily commute gas mileage.
I have the Avids as well.They stop better than the OEM Michelins according to tirerack tests and handle about as well, better in the rain. They last so I won't be improving them for a while, unfortunately.
They are,however a pound or 2 heavier than the Michelins (Bridgestone tires are several pounds heavier) which can affect the mileage. I don't know what the stock wheels weigh, but I bet lighter ones would improve acceleration and mileage.
My mileage dropped when Florida went all ethanol. It dropped after the tire change as well. I am taliking about interstate at night with hardly any traffic with cruise and no A/C. It got better after a tank with BKG fuel injection cleaner though.
Re ethanol - Now, STOP AND THINK a bit here.
If ethanol gets you 10 - 20% less gas mileage and the gas is up to10% ethanol what can possibly be the benefit environmentally or conservation??? One burns the same or more gasoline with ethanol than without so known is conserved, hence the same or more pollution as well, only everyone is buying more fuel at the pump, spending more. Repealethanol as it isn't helping and some engines (especially small and outboard) get damaged by it..
it's a car-drive it
we had the original tires on our tsx from 11/06-5/09-driving on numerous roads, different driving conditions, etc. The gas at the gas stations we use in NC does not contain 10% ethanol. We switched our tires-gas mileage went down-end of story.
NC does not have ethanol? Not all stations get it at the same time when the conversions happen. Do you always look at the pump for the tiny little sign re ethanol?
it's a car-drive it
Have been using this gas station since moving to NC over 4 years ago-no ethanol-no sign and never has been one,. The gas station I use in Fredricksburg Va and also Toms River NJ do have the 10% ethanol sign so I do know what they look like
jdmaszfcuk
10-19-2015 12:31 AM
