HELP! Break light problem
My Tsx has no break light this morning.
I've checked the all the tail lights and I see all lights are good when I turn headlights, but I get no break light when i depress break.
is there separate break light fuse for this in the fuse box? or what is break switch? is it some kind of fuse? where is it located?
Please help.
Please help.
Step 1: Pull the cover off the under-dash fuse box.
Step 2: Flip over and read to see which fuse is for the brake lights.
If your fuses are okay, you obviously need to take it to the dealer.
Originally Posted by jcny
Thanks for the correction.
Any updates on the fuse or anything? You aren't allowed to post HELP!!! about something we haven't seen and then not respond at least every couple of minutes.
Originally Posted by joerockt
Do you have an 04? Did you get the recall done? If not, wiring harness could be the problem.
But I'd already went to dealer for that recall.
I think it's brake light switch issue.
All my light are working fine, i didn't even get tail light warning from the console.
Thanks.
Originally Posted by poltergeist
Brake pedal switch under the dash is a fairly common failure on '03-up Accords. I'd guess the TSX uses the same or similar part.
BTW, Do you know how long does it take to replace and how much it usually cost?
Is it fairly easy job?
Thanks for the repley.
if I recall....don't know about for the TSX.
That said, as mentioned above you should check the fuse/available power to the switch and circuit integrity from the switch to the bulbs before you just "throw parts at it".
If it's under warr...take it to the dealer.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
brandnewcolony
09-12-2015 10:39 AM
HeloDown
09-08-2015 06:51 PM
