Help!!
Old Nov 14, 2005 | 05:45 PM
AirJordan23922's Avatar
Help!!
Alright so last night i drove up from jersey to RI and my subs and everythnig was wroking fine, then we got here took out all the luggage i turned my car back on to drive my friend to roger williams and my amp isnt turning on? My subs kinda work, but they rnt as powerful. I checked the fuse to my battery, but it was fine. Any thing else i can check? So if some1 has any suggestions or pics of what i can look at or anything. Anything will help. Thanks guys.
Old Nov 14, 2005 | 06:01 PM
hawaiiantsx's Avatar
check to see if there is power to the amp.also....check to see if the inline fuse going to the battery from the amp is good.maybe it was just a wire that got yanked out when you were takin out the luggage....good luck
Old Nov 14, 2005 | 06:08 PM
sorry....forgot to mention....the inline fuse from the amp is most likely gonna be under the hood probably kinda close to your battery.....there should be a power wire hooked to your battery with a inline fuse connector on it....hope it helps
Old Nov 14, 2005 | 06:15 PM
CJams's Avatar
Guinea Pig
You might have unplugged your remote turn on wire! So your amp isn't turning on, but your subs work? You might have knocked a speaker wire loose causing it to short out. Don't know, could be a bunch of stuff. Check to make sure all the wires are plugged in to the amp.
Old Nov 14, 2005 | 09:10 PM
Alright guys, im gonna have to do it in the morning, but its driving me nuts. Music without bass is......boring.
