hearing a weird popping sound
Old Aug 29, 2009 | 12:41 AM
deadlyklappy12887's Avatar
when I put the car in reverse and cut the wheel to turn out of my garage in the morning when i leave to go to school. it seems to be coming from the front, i think driver's side. kinda sounds like something snapped in half. any idea what this could be?
on a side note, about a month ago i noticed that my driver front wheel was leaking break fluid b/c the hose wasn't connected tightly but the leak was fixed and last time i had it in for service about 2 weeks ago, nothing was noted on the service report about the leak coming back and that everything in that area looked good.
Old Aug 29, 2009 | 07:08 PM
curls, where are u when i need u? haha
Old Aug 29, 2009 | 07:10 PM
Jaymon's Avatar
CV joint, probably.
Edit: I guess I could have included a little more clarification:
A popping or clicking noise when turning. This almost always indicates a worn or damaged outer CV joint. A quick way to verify this condition is to put the car in reverse, crank the steering wheel to one side and drive the vehicle backwards in a circle (check the rearview mirror first!). If the noise gets louder, it confirms the diagnosis and the need for a new joint or replacement shaft assembly.
Old Aug 29, 2009 | 07:41 PM
curls's Avatar
Someone stole "My Garage"
DUN DAA NAA NAAAAA!!!! Here I am! LOL.
Actually what it sounds like is either the ABS bump thing that our cars do but I don't know if it does it in reverse (like an ABS self-test @ 7mph or 10km/h I believe).
If its not that, and it just started out of the blue, what it could be is the brake rotors have a lot or rust from their overnight lack of use, and once you start backing out, the pads break the rust off of the rotor, sometimes causing a noise.
If that doesn't seem to be the problem, the CV joint test that Jaymon takes a few minutes to try and is pretty accurate.
Old Aug 29, 2009 | 08:06 PM
update: i just went to an empty parking lot and did reverse circles. there was no noise when i was spinning but when i put my foot on the brake during the spin, thats when the "pop" would occur.
Old Aug 29, 2009 | 09:09 PM
curls's Avatar
Check for a seized caliper or a pad that's stuck, even just check the lug-nut torque... could be anything really.
Old Aug 29, 2009 | 09:17 PM
curls's Avatar
Missed the edit window:
Also check with the shop that fixed the leaking caliper to ensure they bled any potential air in that line, from the system. An air bubble could potentially cause the single pop upon first braking.
Also check for any deformed or shifted pad backing plate, seized slider pin(s), or shims on each side of the pad that might have shifted or not been installed properly or at all.
TypeS860
Jan 10, 2026 11:11 AM
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
kixo
Sep 25, 2015 03:07 PM
