AC recharge
AC recharge
I recently bought an 06 Ridgeline that had the AC recharged right before I bought it. I have noticed that it seems like the AC in my TSX isn't as cold or quick as the Ridgeline. Has anyone used a generic AC recharge to service their AC system? My neighbor uses this on his Suburban: http://shop.advanceautoparts.com/web...ram=1251733536
I was hoping that I could save myself a trip to the dealer and recharge the system in my garage.
I wasn't ballsy enough to do it myself. I've read incidences of over pressurizing the system and what not, thus damaging the entire A/C system. Plus getting it done at the shop came with a warranty.
I recently bought an 06 Ridgeline that had the AC recharged right before I bought it. I have noticed that it seems like the AC in my TSX isn't as cold or quick as the Ridgeline. Has anyone used a generic AC recharge to service their AC system? My neighbor uses this on his Suburban: http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_MEASURE-&-CHRG-A-C-Interdynamics_7010015-P_N3571B_C|GRP2004A____?wwparam=1251733536
Do it yourself, it is super easy. Make sure to buy the kit that has the removable hose and not the one that is stuck to the can. I had problems in the past with those. Also like sukemecuke don't get the one with oil, just the refrigerant. Start the A/C and hook up the connection to your low valve (you they are different sizes so you can’t mess it up). Slowly open the valve and tilt the can sideways and shake it slowly until the gauge reads in the green (while the compressor is engaged). It may take up to 10 minutes if it is low. Good luck, once you do it once, you’ll never have anyone else do it for you again. I’ve done it in my Integra, both of our Accords and a Jeep. They do loose a little bit of refrigerant over the years and usually a can or less will give you another 6 years of use (unless it really does have a leak).
zamo
Technology
Mar 31, 2005 02:27 PM
Amoeba
Mar 26, 2005 04:49 PM
NSX-Tuner
May 2, 2003 02:34 AM
