Grinding When Wheel Turned FULLY Right or Left (only front right tire wheelwell)
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
WHAT IS GOIN ON WITH MY PRIDE AND JOY?!?!?!?
so i just drove across the country, put 2700 miles on my car in 3 days, i drive a
2004 Acura TSX 5AT/Nav
lol just to get that straight. i have 72000 miles on it. out of nowhere, if i turn the wheel all the way to the right or left, my front right wheel well makes a seriously scary grinding noise... it does this when i'm in park. not even driving. like lots of $$$$$ scary.... i looked through this thread, couldnt find anything, so if anybody could help me out i'd be much obliged.
Turning the steering wheel until it stops to the left or right is not recommended unless the car is moving, and then even so to use it for a short period of time. What's going on is it's putting stress on the steering pump which can cause damage. Our power steering pump is located to the right side of the engine. Check your power steering fluid level. If it's too low, it will grind when you turn the steering wheel to full left or full right.
Someone stole "My Garage"
Yeah, definitely check the power steering fluid level (pass. side of engine near the mid/front). If it's low, top it up with Honda/Acura power steering fluid ONLY.
Have you had the power steering hose recall done? If not, have that done - they change the fluid in its entirety for you during the procedure.
yeah i had the recall done... when i got my oil changed he checked the power steering fluid, said i was fine. plus i couldnt replicate the noise. thx for the quick replies!
Did the noise start shortly after the recall was done? If so... schedule time with the service department to look at it as it might be air in the PS lines, or debris, etc. You will have to be really professional with them as they will (often) try to say they're not responsible for it, but trust me, with some firm but professional wording, you can get them to at least inspect it and narrow down what the noise is and why it is happening.
it's a car-drive it
(I'm not eligible for the PS Hose recall here in Canada so I really just went on what I read/gathered here at AZine!).
Oakes
Wash & Wax
10-12-2015 11:17 AM
asahrts
09-04-2015 05:55 PM
