Fuel pressure test?
Old Jun 25, 2016 | 01:46 PM
Orangecounty1503's Avatar
Fuel pressure test?
I have a 2005 tsx that has about 260k miles on it, I have noticed while accelerating that it doesn't shift until about 4500rpm's, I have plugged in the code reader and it registered no codes, I was told to do a fuel pressure test on it which I have not yet, but I was just wondering if there are any other common problems that I could check for before I pressure test it, I only have limited knowledge on the mechanics of cars but at the same time, I don't have the finances to replace the fuel pump at this time. I'm not sure if I have even explained the problem efficiently enough to diagnose it, but any ideas would help. Thank you for reading and or for your response
Old Jun 27, 2016 | 08:35 AM
TexasHonda's Avatar
Fuel pressure is unlikely to affect AT shift points. Fuel pressure will affect starting and drivability (poor acceleration, missing).
I checked shop manual and did not see anything in the symptoms diagnostic chart that directly applied to your problem. If ATF has not been recently changed, it would be worth a replacement. Some problems are fixed by replacing ATF. Cost of fluid is <$50.
good luck
Brad2Taylor
1G TL Problems & Fixes
Jun 20, 2016 10:41 PM
Rob_TL
20
May 25, 2016 01:43 AM
wlbrtsmth3
Mar 24, 2016 03:08 AM
Nala Gonzalez
Feb 18, 2016 05:51 PM
DJMikeT
Jan 6, 2016 11:57 AM
