Fuel light flashing.
Hey guys. When I started my car up today, the fuel light was flashing and the fuel gauge was stuck at E. This came as a surprise because I just put gas in the car yesterday. I checked the fuses under the dash and they seem to be alright. Has anyone had this problem before? If so, then please help me out. Thanks in advance.
Did you start your car on an incline? Take it to a flat piece of road and restart it. That's the only time something like that has happened to me. Unless someone siphoned your gasoline
I just started the car in my garage. It is on a flat piece of ground. It didn't help. I did get into the diagnostic mode and check the trip information and it displays everything. When I check the range in normal navi mode then it doesn't show anything.
MAC USERS RULE
This might help
ACURA TSX 05-06 RECALL!!!!!!!
Fuel pump Problem!!!
http://news.yahoo.com/s/ap/20070319/...honda_recall_1
Originally Posted by JAXFLTSX
This might help
Look at item #37 below (fuel pump assembly) and note the bottom where a square component (float) that is connected to the fuel pump via a rod. That is the fuel gauge sending unit. It could be defective not sending the correct signal. The dealer will have to replace the sending unit or the fuel pump assembly.
Originally Posted by JTso
Are you 100% sure there is gas in the tank? You mentioned filling gas recently, but is it possible someone stole gas from your tank? If you shake the car a little, can you hear gas inside the tank? An empty gas gauge + no starting usually means no gas...
Originally Posted by visuelz
How do you steal gas from someone when the gas door is locked?
Just dial 1911
1 Post
Originally Posted by aaronng
If it was the fuel pump, wouldn't it still be under the recall and thus repaired free of charge by Acura?
NBP_BALLER
09-23-2015 08:18 PM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
