Front door locks
Old Aug 13, 2013 | 05:37 PM
mouh60's Avatar
3rd Gear
Front door locks
Hi,
I'm new to this site. i need some advice/help.
I have a 2005 TSX. Bought it brand new and other than the recalls I haven't had any issues up to the past week. All of a sudden, the front door locks wont work with the remote. They still work manually and with the key from the outside but not with the remote. The back door locks/trunk/panic button work just fine with the remote. I reprogrammed the remote but the front door locks are still refusing to work. I'm assuming that because the remote operates the back door locks it shouldn't be the remote battery. I'm stumped. Any help or ideas would be greatly appreciated.
Old Aug 13, 2013 | 06:53 PM
Simba91102's Avatar
Old Guy
Originally Posted by mouh60
Hi,
I agree that since all of the functions other than the front locks work, that should indicate that the battery is OK, but.... I'd still replace it (trust me, it's ready, and assuming you still have the second remote tucked away somewhere, change that one too. You may find that it's dead from lack of use; I did). Since the key will operate all of the locks (and/or just the driver's door lock I assume), that should point to the remote as the problem and replacing the battery seems the logical place to start.
Old Aug 13, 2013 | 06:58 PM
Simba91102's Avatar
Old Guy
Oh, and welcome to the site. I had an 05 till last January and loved it. Bought it new, we put 178K miles on it, and it was still perfect when I finally sold it. Probably the best car I've ever owned (and I've owned a ton).
Old Aug 13, 2013 | 08:02 PM
mouh60's Avatar
3rd Gear
Thanks for the reply. I will replace battery tomorrow and keep you updated.
Old Aug 14, 2013 | 04:59 PM
mouh60's Avatar
3rd Gear
Changed the battery on remote. Front doors locks still not working. I read on another posting that the door lock actuators like to go bad on Acuras. Man, I don't want to go to the dealer. Ugghhh
Old Aug 14, 2013 | 07:25 PM
Tangoman's Avatar
You don't need to go to the dealer. Battery is not the culprit - front power lock actuator has died - read this thread, its a pretty easy fix.
https://acurazine.com/forums/1g-tsx-problems-fixes-128/diy-how-replace-front-power-lock-actuator-690275/
Old Aug 14, 2013 | 10:02 PM
alxlxiv's Avatar
Yes, follow that thread. I just replaced the actuators about a month ago and it wasn't too terribly hard. I am a novice when it comes to cars too. Just read over that entire thread, also look up TSX actuator on youtube. There is a pretty good video on there. You can find the actuators online for around $15 a piece.
Old Aug 15, 2013 | 05:36 AM
Simba91102's Avatar
Old Guy
Keep us informed on what you find. I'm skeptical of the actuator fix only because when I've had one go bad, nothing will make it work (the door lock won't work, period). But since it's evidently not the remote, the actuators are about the only thing left in the mix to address.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
08 NBP TL
Sep 8, 2015 08:49 PM
