Fog light
Old Aug 6, 2005 | 05:18 PM
mikyacura's Avatar
5th Gear
Fog light
My fog light just broke--both sides-- on my 2004 TSX !?
i did not know this is a problem with Acura. Are there a recall for the fog light?? What is the cheapest way to repalce them other than paying 98 dollor each??
Old Aug 6, 2005 | 07:11 PM
Alin10123's Avatar
No recall. Check the fuses.
Also, you need to have the headlights on in order to turn on the foglights. Also check all of the wiring connections.
If that does work... maybe the bulbs just went out.
Old Aug 8, 2005 | 02:08 AM
mikyacura's Avatar
5th Gear
It is the galss and not the bulb
Old Aug 8, 2005 | 05:17 AM
moda_way's Avatar
Griot's garage, 3m, etc all make an a rock guard that you can cut to fit over the fog lights to protect them.
Old Aug 9, 2005 | 06:26 PM
mikyacura's Avatar
5th Gear
TSX fog light
Is there a place I can purchase the fog light and not the whole kit?
Old Aug 9, 2005 | 06:30 PM
BDI's Avatar
BDI
ebay is the cheapest.
Old Aug 9, 2005 | 07:04 PM
Adrena's Avatar
Besides ebay, you could try wreck yard that sells used parts. They should have some TSXs that have been totalled in the rear and that could/would still have fogs...
Old Aug 9, 2005 | 08:23 PM
TSX 'R' US's Avatar
Old fart
I'll buy the replacement stalk from you if you get the whole kit...
Old Aug 10, 2005 | 11:44 AM
mikyacura's Avatar
5th Gear
Does any parts store sell the fog light ONLY??
Old Aug 10, 2005 | 02:14 PM
moda_way's Avatar
Go to HandA.com and buy the correct side for an Accord. Costs $100. I just replaced mine about 2-3 months ago and got mine from them. It is the same part.
Old Aug 12, 2005 | 06:03 PM
mikyacura's Avatar
5th Gear
thanks
Old Aug 30, 2005 | 08:10 AM
dmbfan36_23's Avatar
Did you end up buying the lens like moda_way suggested?
I'm freaked about my fogs busting... I'm considering the mesh guard job since the clear bras all seem to brown... argh!
Mesh Guard (Post #47 and replies from there on out):
https://acurazine.com/forums/showthr...9&page=2&pp=25
Old Aug 30, 2005 | 09:04 AM
moda_way's Avatar
That is one sad fact of the clear material... it does go brown. I'm thinking of looking into the mess. I just don't want it to look all funky.
Old Aug 30, 2005 | 09:09 AM
Howard911s's Avatar
HOWARD911S
check this site.. they have both lens..
http://cgi.ebay.com/ebaymotors/Acura...temZ7996135664
Old Aug 30, 2005 | 11:35 AM
yuhoo22's Avatar
John Starks - The Dunk
Just go to ebay and by the replacement for the RSX or a Civic. That is what I ended up doing, it only ended up costing me $25. You just have to you the hardware that came off the TSX to re-attach.
Old Aug 30, 2005 | 11:39 AM
yuhoo22's Avatar
I ended up getting the light protectors afterwards also....here are a couple of pics.
If you buy the OEM ones again, they are just going to break again. Trust me I went through 2 sets of OEM fogs.
Old Aug 30, 2005 | 11:43 AM
yuhoo22's Avatar
I haven't had a problem with my protectors browning....and I run them all the time. The company I bought it from said they are rated to handle up to 300 degrees. So far so good for me.
Old Aug 30, 2005 | 11:52 AM
moda_way's Avatar
I assume you can get a clear set? I just have noticed everyone's clear protectors have browned. MrChad had the same issue and sent them back to Griot's. They just offered to send him more of the same. I'm skeptical at this point, but I have a few more pieces to use.
FYI, I've also broken a fog light with the protector stuff on. That kinda sucked.
Old Aug 30, 2005 | 12:16 PM
acura_integra's Avatar
I used 3M smash guard and it turned black, what company makes the one you have?
Old Aug 30, 2005 | 05:12 PM
yuhoo22's Avatar
Lamin-X
moda....it comes in 4 different colors + a clear. Also in the clear there are several thicknesses available. I just bought the sheet though, it saves you a little bit of money and gives you room for error.
Old Aug 31, 2005 | 07:06 AM
moda_way's Avatar
Lamin-X
I will try this as soon as I run out of my current stuff.
I used a sheet too and cut out for the fog lights.
Thanks!!!
Old Aug 31, 2005 | 10:41 AM
digitalHorizon's Avatar
i know this is late, but I have a brand new set of OEM foglights only that I'll sell you.
Old Aug 31, 2005 | 11:52 AM
TSX 'R' US's Avatar
Old fart
Lamin-X
I might have to try them out... I'm on my second set of the 3-M ones and they will brown if my car isn't moving. In fact, they've got some brownage on them right now
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
