Exhaust Fumes in Cabin after Starter Replacement
Old Dec 26, 2023 | 02:26 PM
npolite's Avatar
Hi All,
I just noticed that exhaust fumes are a stronger now at idle after I replaced my starter which involves removal of the intake. I did not replace the metal gasket as others mentioned you really don't need to. Is it possible that is where the smell is coming from? I torqued the bolts per the manual which I think were 16 ft/lbs if I recall. Any help would be appreciated.
Old Dec 31, 2023 | 03:35 PM
npolite's Avatar
Here is the update. I got the smoke machine and hooked it up to the exhaust. It took a little while but I was able to find the leak. It is in the a-pipe, probably in the flex pipe area. It could also be in the gasket. I'll jack the car up on Tuesday to confirm but most likely I'll need to bring this in for a repair.
Old Dec 20, 2024 | 02:04 PM
haniforama's Avatar
You may have left off a vacuum line or EVAC purge line during the re-installation of the intake manifold.
Old Dec 21, 2024 | 06:51 AM
npolite's Avatar
Thanks for the reply. It was the A-pipe and was replaced.
main70072
1G TL (1996-1998)
28
Feb 21, 2025 03:25 PM
Domenic DeGregorio
Oct 16, 2016 06:02 PM
r.soodeen
1G TL (1996-1998)
Nov 9, 2009 02:36 PM
jazo
1G TL (1996-1998)
Sep 24, 2002 03:47 PM
