engine idle problem
Old Jul 24, 2006 | 08:07 PM
mvbadboy's Avatar
engine idle problem
hey guys i need help a.s.a.p. .... i have a 05 tsx and i checked my fuses cause my rear defog. wasnt working.. so when i started my car up the idle was going up to 2 and then dropping down to 1 repeatidly... the vsa light is on and when i try to drive the car the gas pedal doesnt respond and the car moves by itself only to 20mpg..please help!
Old Jul 24, 2006 | 08:17 PM
jmathew34's Avatar
umm is the check engine light on?
when you start up the car does the VSA light flash a couple times? if so how many times? you can call the dealership with this information and try and get a diagnosis over the phone but i'd suggest calling roadside assistance to tow your car to the nearest dealership to get a diagnosis....
you could always disconnect the battery and see if that helps....but then you would not know what caused this issue to occur...
Old Jul 25, 2006 | 10:18 AM
mvbadboy's Avatar
thanks ill try to disconnect the battery and see what happens
the vsa light just stays on..and no flashes
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
NSolace
Sep 3, 2015 08:14 PM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
