Down Shifting problem?
Old May 20, 2010 | 01:45 PM
tbo12485's Avatar
Unhappy Down Shifting problem?
I just bought an 06 5speed automatic TSX. When I am slowing down on the highway or off ramp the RPM'S shoot up and then drop really quickly and jerks a little bit. Is this something to be worried about? Has this happened to anyone else? Realllly worried.
Old May 20, 2010 | 02:36 PM
tbo12485's Avatar
anyone?????
Old May 20, 2010 | 04:37 PM
LuvMyTSX's Avatar
Are you going downhill while slowing down? If so, it might be the grade logic control feature. It has a tendency to be a bit jerky sometimes.
Old May 20, 2010 | 06:22 PM
Simba91102's Avatar
Old Guy
Originally Posted by tbo12485
anyone?????
It's normal. The transmission is mirroring what most would probably do with a manual transmission (while slowing down fairly quickly, especially going down an incline). It downshifts, then it unlocks the torque converter to mirror either depressing the clutch or a shift into neutral (this is why the engine rises in RPM's as it downsfifts, then can fall rapidly too). Personally, I count on it/use it and think it's pretty cool.
Old May 21, 2010 | 03:17 PM
MinhNhut's Avatar
4th Gear
Dirty Injectors
I had a similar problem but not exactly like that. When letting go of the pedal for slowing down, the rpm revs up and sticks around 2400 for a few seconds. It would only drop once I apply the brake to slow the car down, this made the car feels as if the tranny was hunting. This got to the point where my gf started to noticed it too while sitting in the passenger seat. However, a colleague told me that I might have dirty injectors which causes the rpm to hang. I would've never thought of that but since he races karts for a hobby so I decided to give it a try
After using some Lucas injector cleaners, the problem disappeared.
And yes, I use 91 octane minimum.
152,000 km
05 TSX, Auto
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
jfman55
Sep 5, 2015 02:55 PM
