Door Sqeaks
Door Sqeaks
okay well i guess at the 10k maintence all they did was do a half-assed job rotating the tires and replacing the oil. why would the rotate the omni directional stock tires like the uni ones. the moved the fronts to the back and back foward...argh
well i went to autozone and they gave me some diaelectric grease to put on the doors. i put it on the right rear side and it still squeaks, maybe im not doing it correctly... im not very happy right now with acura.
finished my tire road rash fixing job today. looks halfway decent now, just a big project, and you need tons of patience.
i have pictures if u guys want.
layter
thnx again
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
layter
thnx again
layter
thnx again[/QUOTE]
Pics of the road rash fixing would be great. Have a bit one of my tires I need to fix, wasn't me that caused it which makes me even more upset everytime I see it.
layter
thnx again[/QUOTE]
layter
thnx again
layter
thnx again
honestly the ammount of work thats involved in doing it your tire would have to be really rashed. i had half the edge of my rim gone and i still think i did more work than was really necissary. the biggest problem is the paint, there is no paint to match properly, and the ones that are out you have to be really really good at it for it to blend,
now theres no discolored road rash just an offsilver spot with some grey primer seeping through.
Bye TSX, hello domestic?
Originally Posted by Xtremespeed2102
dooor help people! someones gotta have info on this, either past expirence or the helms or something
I believe i read somewhere that there's a special recommended lubricant that comes from Japan that the dealer used. I think the dealer actually used it to fix a squeek and a rattle.
no im hearing it as i open the door im assuming down by that black thing that tells the door how far to open n where to stay open. i tried putting the diaeletric grease on it but it still is there
im going to resurrect this thread. iv'e been having the door squeek at the same spot you are for as long as i can remember. makes my car sound like a 20 yr old car! any suggestions anybody?
Car lust never sleeps
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
Originally Posted by Errowen
A loud screech as the door moves past the detent indicates a broken hinge. This is a very common wear issue with pressed-steel hinges. The hinge will continue to function perfectly when broken, but under protest because the two parts of the hinge tube wearing against each other at the break. You may feel the door drop half a centimetre as it crosses the detent. Grease will be a fix for a week or two, but the screech will return until the hinge is replaced.
My own problem is a low volume rattle in both doors, which only shows up at high speed.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
are you talking about the two hinges that are mounted on the car or that black piece that slides into the door? the door opens fine and it doesn't drop a centimeter like you said. please elaborate.
soupi
14
11-15-2015 11:15 AM
