Door Lock Knob FIX!!!
Old Aug 6, 2003 | 01:11 PM
LurchRSX's Avatar
1. Unscrew knob.
2. Grip in clamp at the flat area (shaped like a bolt/nut)
3. Mark off 1.5" on a 5/32" Drill bit (so that you know where to stop)
4. Drill the core out slowly making sure not to go too deep.
5. Mark 1" from the bottom of the "bumpy area" on the lock knob.
6. Cut off at 1" mark using a mounted jig saw, hand saw or other safe means.
7. Sand rough edges
8. Install and enjoy.
Old Aug 6, 2003 | 01:13 PM
LurchRSX's Avatar
Pics to follow........can someone host for me?
Old Aug 6, 2003 | 01:45 PM
bowersan's Avatar
Integral & Acurate TSXer
I'd be concerned that when you drill into the bit, there would be no creation of threads- and therefore, when you pull on the lock, it might slip.
Or I might be completely off base. Im glad to hear someone has done it! I cant wait to see the pics.
J.
Old Aug 6, 2003 | 02:10 PM
XPLORx4's Avatar
My other "car" is a 4x4
I don't get it. What does this mod do? Make your door lock tabs flush with the door panel when locked?
Old Aug 6, 2003 | 02:27 PM
LurchRSX's Avatar
Thats exactly what it does.........sorry I guess I just assumed people would understand. Doh
Someone please host the pics PM me!!
Old Aug 6, 2003 | 03:08 PM
LurchRSX's Avatar
Old Aug 6, 2003 | 03:28 PM
LurchRSX's Avatar
Better / bigger pic.........
Old Aug 6, 2003 | 03:43 PM
Visorboy's Avatar
Thumbs up
Good job Lurch! I was waiting for someone to do that.
We should have a lock stub shortening meet at your place. BYOB j/k
I'll give it a go and see if I can do it...let's hope I don't f*** it up :p
btw, check your hotmail account.
Old Aug 6, 2003 | 09:22 PM
the_peel's Avatar
Sweet job Lurch! Thanks for the info and pics. I'm probably going to try this soon (probably this weekend). BTW, for those without the aero kit, have you thought about removing the front mud guards? I read an article on vtec.net and they stated that the mud guards scratch the paint and suggested removing them asap to avoid further damage to the paint. I've taken them off today (after a month and a half of owning it) and already noticed scratches in my paint.
Old Aug 7, 2003 | 06:13 AM
moda_way's Avatar
Sweet mod.
Old Aug 7, 2003 | 08:28 AM
LurchRSX's Avatar
hey peel.....thanks
Old Aug 7, 2003 | 08:51 AM
LurchRSX's Avatar
BTW you can p/u knobs from the dealer for $3.80/pc so you don't have to mess up the original ones.
Old Aug 7, 2003 | 10:06 AM
DEVO's Avatar
i see the pics... but i don't know what was done, can somebody explain?
Old Aug 7, 2003 | 10:47 AM
LurchRSX's Avatar
The knob now comes flush with the door instead of sticking up 5/8" and jabbing your tricep.
Old Aug 7, 2003 | 11:04 AM
XPLORx4's Avatar
Do you modify only the driver's door, both front doors, or all doors?
If you mod the back doors, your rear passengers can't unlock them from the inside...
Old Aug 7, 2003 | 11:14 AM
LurchRSX's Avatar
Just the front doors....the back door locks are far enough back the it does'nt bug anyone
Old Aug 7, 2003 | 10:15 PM
the_peel's Avatar
Just did my driver's side tonight. SWEET!!! Lovin' the ride now!
Old Aug 8, 2003 | 08:33 AM
LurchRSX's Avatar
How did you find the mod? easy? medium? difficult?
congrats
Old Aug 8, 2003 | 08:41 AM
the_peel's Avatar
Very easy. Took me all of 15 minutes to do the driver's side. After that, it took me about 5 minutes to do the passenger's side. I agree with you that the rear door locks don't need to be "fixed".
Old Aug 8, 2003 | 09:59 AM
LurchRSX's Avatar
Glad to hear that
I took me 1 1/2 hours and one messed up knob to do mine.....measure 10 times cut once
Old Aug 8, 2003 | 10:29 AM
fdl's Avatar
fdl
Hey lurch this is great stuff. I'm a littel confused by your instructions though. All the drilling and cutting and sanding, is that all done to the actual knob you pull out...or to the hole in the door??? If someone wants to post pics of the process, thjat would be awesome
By the way peel. about the mudguards. I took mine off as well and luckily there was not permanent damage yet. I am going to buy that protective film, and stick that on under the flaps just like Chad ssuggested.
Old Aug 8, 2003 | 10:40 AM
XPLORx4's Avatar
The pull-up tab is the piece that you perform the surgery on.
I unscrewed the driver's side tab last night to check it out myself. When I have time I might do this.
By the way, don't you find it odd that there are door-lock tabs on the front doors at all? I mean, the driver's door has the lock/unlock button, and the passenger door has a similar switch by the door handle. Why are tabs also needed?
Old Aug 8, 2003 | 12:23 PM
the_peel's Avatar
I believe the tabs are needed as they are mechanical links to the actual door locking mechanism. In the event that the electrical units lock switches fail, you can still unlock the door with the pull tabs.
So, by doing this surgery, you will not be able to unlock the door if there is an electrical malfunction of the switches.
Old Aug 8, 2003 | 12:52 PM
fdl's Avatar
fdl
Very good point. That might make for a dangerous situation.
Old Aug 8, 2003 | 01:05 PM
moreace_RENAMED's Avatar
wouldn;t getta have the same problem? In that once in a life time situation crawl your lazy ass in the back seat
Old Aug 8, 2003 | 01:17 PM
fdl's Avatar
fdl
getta? Whats that?
Sometimes the back seats might not be an option. Its unlikely..but its possible that you could be put in a situation where you need to get out of the car and can only use the front doors.
Old Aug 8, 2003 | 01:20 PM
sux to be u, fold down the back seats and see if there is a manual release in there for the trunk. be inventive. Just do the mod to the drivers door as you paid for the car and it is only your comfort you should care about. Then you get to put your arm out the window and u can use the passenger door, unless the circumstance is blocking all 3 doors adn just not the drivers
you know, the VW Getta
he he, I meant Jetta
Old Aug 8, 2003 | 01:24 PM
fdl's Avatar
fdl
When your back end is smashed, and your car is on fire..i'd like to see how "inventive" you will be. And I dont think comfort should come befor saftey in general.
But I am not saying dont do the mod...just that its something you need to be aware of thats all. (I may do it as well).
Old Aug 8, 2003 | 01:32 PM
General safety my ass, U'r ideas of what COULD happen are generally retarded. A number of cars have recessed lock, which oulw not be allowed by the covernment if unsafe. What if when you got hit the locks got unhinged. Happened to my friends Saab. You can pull the lock up and down all you want, but the door isn't unlocking. Why don't you get rid of you car, go buy a Wrangler, take the doors ofd, and stop being an idiot. I could come up w/ a million scenarios that would never happen to make anything look unsafe.
Larch, where the hell are you? Get in on this one.
Old Aug 8, 2003 | 01:33 PM
Count Blah's Avatar
'12 TL (prev '04 TSX 6MT)
... and it's probably something to keep in mind when it comes time to sell your car. You'd need to restore it to original condition or at least let the buyer know about the comfort > safety trade-off you made.
Old Aug 8, 2003 | 01:39 PM
Count Blah's Avatar
The difference there, which we've discussed before, is that a pull of the door handle will unlock the door (in the Jetta, for instance). In the TSX, you have to pull on the tab. If you can't pull on the tab, it increases the likelihood you'll be locked in the car. Not a one-in-a-million trivial scenario at all.
Old Aug 8, 2003 | 01:40 PM
fdl's Avatar
fdl
moreace , you are by far the biggest idiot on the site. Either you are 12 years old, or you are an uneducated adult with can barely speak english.
I never said it was a BIG safety risk...just something to keep in mind. Some scenarios are unlikely...but possible and some people might be bothered by the fact that without power they cannot get out of their car. I never even said I was bothered by this..but you jump in and say i'm and idiot and my ideas are retarded. Grow up, or go back to school.
captainjack's Avatar
Über Geek
From the picture, it looks like there'sjust enough of the knob to pull up with your fingertips or a key or something in a pinch.
Old Aug 8, 2003 | 01:45 PM
I am not 12 (not even close)
I am VERY educated
I speak fine, just type too fast and don't proof read (don't care)
Seems like you were making it a huge deal. My car is 9 years old and has never been w/o power. It just seems like you are using scare tactics towards people who are considering the mod. I don't think it is an issue at all. It might be somethign to keep in mind, but you are trying to drill it in like anyone who does it is going to die and their car will catch on fire. It was not an objective overview of the situation in my eyes. Was ehavily weighted only towards and event that seemed extremely unlikely to occur
Old Aug 8, 2003 | 01:52 PM
fdl's Avatar
fdl
I am VERY educated
Well I dont think I was giving scare tactics at all. I just think people should be aware of POSSIBLE risks. I specifically said that I am not saying dont do the mod, and I may even do it myself. The fact that you can't unlock the door without power is something people need to be aware of, and then they can make up their own minds about doing it.
And regardless of what my opinion is, dont call me an idiot.
Old Aug 8, 2003 | 01:58 PM
LurchRSX's Avatar
stop fighting you guys
Old Aug 8, 2003 | 02:06 PM
XPLORx4's Avatar
This whole discussion took on an entirely different personality!
Actually, I didn't realize that other than the lock tabs there is no other way to unlock the doors mechanically from the inside. So, theoretically, if you have the child-safety switch engaged on both rear doors, you lock the car and somehow you let the battery die, with this mod, you can't get out! well, except for possibly climbing through the trunk...
Old Aug 8, 2003 | 02:10 PM
LurchRSX's Avatar
If you guys are concerned about lock malfunction cut 1.125" from the grip and leave yourself some area to grab.
Old Aug 8, 2003 | 02:12 PM
Or just don't do the passenger side
what do you think IDIOT (fdl)?
:P
Old Aug 8, 2003 | 02:19 PM
dom's Avatar
dom
Be careful not to attempt this mod while driving
Not only is it a safety hazard but your lock may fall into the door
The only idiot around here is me......
