Door Actuator
Door Actuator
Hi everyone like many of you, my Door Actuator finally gave in. I know there is a lot of threads about the actuator already but I wanted to see how many of you have had this problem, so please If you have had this problem, raise your hand.
1. Roci 05AT TSX (57,000 miles)
2.
3.
4.
5.
2.
3.
4.
5.
2. https://acurazine.com/forums/showthr...+lock+actuator
3. PACman
4.
5.
3. PACman
4.
5.
Rep'n Taxbrain.com
2.
3.
4.
5.
2.
3.
4.
5.
2. PacMan
3. Tsx536 04AT TSX (At 47K miles Front Right went bad, at 85K Front Left Went bad) Also installed new acutators for about 3 other forum members
4.
5.
Basically, it seems to be a very common problem!
I don't think I can create a poll that is why I did the list.
I will be taking my car in tomorrow I was hopping a lot more of you would add your name so that I can take it to them to see it is a common problem, and maybe get it repaired with a discount or maybe they would consider replacing it under warranty in good faith, (mine is expired), and eventually it would help others with the same problem. I know it is an easy fix but I have 0 mechanical abilities, and would probably end up breaking something els.
Thanks to those of you who put your name on the list.
2. PacMan
4. Wong05tsx (Pass. side ~ 30k miles)
5. dom (Pass. side ~ 65K miles)
2. PacMan
2. PacMan
6. Marathon (driver side ~44k)
2. PacMan
Sweet!
2. PacMan
7. thunder04 (drivers side ~ 60k)
2. PacMan
2. PacMan
7. LoveMyTSX - Drivers side 70k miles
2. PacMan
2. PacMan
8. LukeaTron - Front-right and left-rear both need to be replaced @ 58k. Been to busy to take it in. Dealer told me they see a lot of this in the TSX and RL. Same part maybe?
2. PacMan
NBP/EBONY/6MT
2. PacMan
9. TSXSurf - driver's side @ 40k miles
2. PacMan
2. PacMan
2. PacMan
2. PacMan
10. Neo661 (04 TSX. went out at about 80K, there are alot of threads on this...its really easy to install...cheap part too...about 18 bucks @ www. oemacuraparts.com )
Today 4:31 PM
11. Miamicarfan (05 TSX. went out at about 33,000. Drivers side door.)
2. PacMan
Today 4:31 PM
2. PacMan
Today 4:31 PM
12. chhimp (04 TSX went out at 70k. Driver's Side)
2. PacMan
Today 4:31 PM
05 Crew
2. PacMan
Today 4:31 PM
13. iVTECdailyy (05 TSX, went out at 27,000. Front Right Side)
2. PacMan
Today 4:31 PM
2. PacMan
Today 4:31 PM
2. PacMan
Today 4:31 PM
2. PacMan
14. XAKEP (04 tsx, 93000, both front stick, driver and passanger)
2. PacMan
15. Evenq (Driver Side 05 TSX, 44k)
2. PacMan
2. PacMan
16. PhiDelt (Justin Reitsma) '05 TSX driver door, 67,000 kms
2. PacMan
2. PacMan
17. peterjedi 2004 TSX with 61,000 miles.
2. PacMan
Oh well it's
2. PacMan
18. wickedk24 2004 TSX (Driverside went out at 75,000 Passenger at 50,000)
2. PacMan
2. PacMan
19. green_henry 2005 with ~30k
2. PacMan
2. PacMan
20. eve - Driver's side, 2004 ~35k miles
2. PacMan
2. PacMan
21. Ol'DoogyDoggy - Driver's, 2005 ~35K miles
2. PacMan
2. PacMan
22. Xtremespeed - Driver's, 2004 - 40k
2. PacMan
2. PacMan
23. dP21 - driver, 2005 ~50,000 KMs
2. PacMan
2. PacMan
24. xaznperswaesonx 04 tsx passenger @ 30k ish
side note: its a common problem because the door lock motor itself uses plastic internal gears
2. PacMan
2. PacMan
25. sabby- 2004 passenger front @ 64,000 miles
2. PacMan
2. PacMan
26. lookin_badass 2005 passenger front @ 60300 miles
2. PacMan
Brum Brum!!
2. PacMan
27. cober319. 2004 driver and front passenger starting to go slow 41,000 miles
2. PacMan
I think I have had all my actuators changed out of all me doors. They are purely junk especially when they start wheezing. Definitely add me to the list.
2. PacMan
28. kaliraver69 All four doors, wheezing and one died completely 4x,xxx miles
2. PacMan
2. PacMan
29. ying- 05 drivers side ~70000Km
2. PacMan
SSM FTW
2. PacMan
29. ying- 05 drivers side ~70000Km-
30. luder917 - replace drivers door ~65k, passenger going out
2. PacMan
2. PacMan
31. bluexcrush - driver door ~ 95,000km, $100 P&L
2. PacMan
Panzerkampfsnowzen
2. PacMan
32. coronad0 - '04 TSX, all the doors, right at about 75k.
2. PacMan
